My audio question
Old Dec 31, 2011 | 06:19 PM
alex23's Avatar
alex23
Default My audio question
Hey guys i have a question in how to wire a second amp. At the moment i have a 4 channel (jbl14001) powering 2 10" mtx jackhammers. The wire is a 4 guage thats powering the amp. Now the question is how would i put my new amp (jbl gto mono amp i think 700) to the subs and use the other one for my speakers which are also jbl 2ways. Do i need to run another wire from the battery and how do i connect them both with the rca cable. Also is do i connect the second amps remote wire and should i get a capacitator.
Old Dec 31, 2011 | 07:02 PM
beezee's Avatar
beezee
I am not an audio guru but can be of a "little" help because I am in the middle of an audio project myself. I am not sure about the power of your subs but you have these choices.
Get yourself a distribution block and install it somewhere like in one of your rear cubbys.
Connect the 4 gauge wire you have now to it. Then run two 8 gauge wires from it (one for each amp). This depends on the power of the amps and whether you can use 8 gauge wires.
If not then ran a new 1/0 gauge wire to a distribution block. (you will remove the present 4 gauge). Then run two 4 gauge wires from the block (one each for the amps).
The second amp will need a remote wire too. You can tap into the same remote wire for the first amp
Old Dec 31, 2011 | 07:06 PM
alex23's Avatar
alex23
Subs are 600 wats each. Mono amp is 1000 wats. 4 channel is 600 wats. I already purchased another 4 guage amp kit. Whats a distibution block
Old Dec 31, 2011 | 07:20 PM
beezee's Avatar
beezee
"Distribution" block not distibution. Better to google it for pics and uses. It accepts inward wire and has outlets for smaller wires. Like 4 gauge in and two 8 gauge out. If you have already purchased another 4 gauge wire, you can ran that the same way as the other to the second amp. It is more hassle and not a popular way. I bought two 4 gauge amp kits too but decided to go the "distro" block direction. More convenient in my oppinion
Old Dec 31, 2011 | 08:18 PM
beezee's Avatar
beezee
This might explain it better.
https://my350z.com/forum/exterior-an...-question.html
Old Dec 31, 2011 | 08:21 PM
alex23's Avatar
alex23
Thanks man
Old Jan 2, 2012 | 12:40 AM
Sometimes audio questions can be confusing because you are asking members to visualize what you have. Often a simple pencil diagram is helpful.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
