Sugggestions on 2 10" subs that aren't gonna break my wallet?
Old Mar 12, 2012 | 07:19 AM
codyiscool's Avatar
codyiscool
Default Sugggestions on 2 10" subs that aren't gonna break my wallet?
I like the deep/low bass. I wanted 2 tens under the sway bar. I have a 2ohm amp right now in my old car that is power two kicker cvr12's...I'd like to use the same amp. The amp is 1600-18000 watt amp it's a cadance zrs class c.....I'm loooking for 2 10's...what do you guys suggest?
Do the subs have to be 2ohms like the amp is?
I know nothing about this stuff so if you guys could reccomend me something for someone not looking to spend a crazy amount that would be greatly appreciated
Old Mar 12, 2012 | 07:29 AM
NZMOWND's Avatar
NZMOWND
i have a couple 10" alpine type R's that are pretty good for the money
Old Mar 12, 2012 | 08:05 AM
bmccann101's Avatar
bmccann101
fist, theres no way its 1800 watts. Moot point tho..
Second, to answer the actual question, JL Audio 10W0s are great.
Old Mar 12, 2012 | 12:42 PM
JMII's Avatar
JMII
Sealed, small box? I run Polk MM's.
2 ohms stereo or mono on your amp? Lots of possibilities... this should help: http://www.rockfordfosgate.com/rftec...er_wizard.asp?
Old Mar 12, 2012 | 05:08 PM
codyiscool's Avatar
codyiscool
What kinda box? Ported or no?
Old Mar 12, 2012 | 05:11 PM
codyiscool's Avatar
codyiscool
My amp says two oh? Do I need two ohm subs? Or can i use 4? Im lookin for 2 10s priced decent with low/deep bass
Where should I get my box? Do ones that go under the away bar come ported?
Old Mar 12, 2012 | 05:36 PM
Ruthless18x's Avatar
Ruthless18x
www.sonicelectronix.com
Old Mar 13, 2012 | 05:16 AM
blackonblack350's Avatar
blackonblack350
Yes if you have a 2 ohm amp you must have 2 ohm subs also to match the amp. Jls would be my first pick for best quality/bass, but if you want to go cheaper than that mtx subs are good subs for the money.
Old Mar 13, 2012 | 06:40 AM
NZMOWND's Avatar
NZMOWND
That is my box, i custom made it from fiberglass and it is sealed...it wedges between the strut bar and the back...
Attached Thumbnails Sugggestions on 2 10" subs that aren't gonna break my wallet?-img_1581.jpg
Old Mar 13, 2012 | 08:34 AM
xNeo's Avatar
xNeo
I'm not sure what your budget is but take a look at these:
http://www.onlinecarstereo.com/CarAu...o_D110D22.aspx
Old Mar 13, 2012 | 04:43 PM
TURBOROADSTER's Avatar
TURBOROADSTER
If you have a Mono amp , you need to buy either (2) 4 Ohm single voice coil subs , wire them in parallel and your amp will see a 2 ohm load . Or you could buy (2) 2 ohm dual voice coil subs , wire the coils in series (4 ohm) then the subs in parallel and your amp see's a 2 ohm load .
Old Mar 16, 2012 | 06:21 PM
codyiscool's Avatar
codyiscool
WOW. how much would you charge for one? anywhere that sells something similar online? i don't need it fancy just like where it fits, and i only wanted 1 12" sub as 1 10" wouldn't be enough, and 2 10's might be more money that 1 12"...plus i already have 2 12" kicker CVR12's (400rms) and if one ever blew or got stolen i'd have a back up...is it ported/
Obadabot
Jun 18, 2023 11:31 PM
May 30, 2017 03:28 PM
Tochigi_236
Sep 27, 2015 03:40 PM
