Question about throwing amp in stock sub location
Old May 15, 2012 | 04:28 PM
pigpimpc's Avatar
pigpimpc
Default Question about throwing amp in stock sub location
Does anyone get scared that a spark might ignite the gasoline and engulf the whole car in flames? Am I just paranoid?
Old May 15, 2012 | 06:22 PM
While you are at it throw on a turbo and throw on some twenties.
Old May 15, 2012 | 06:31 PM
Spike100's Avatar
Spike100
Are you kidding?
--Spike
Old May 15, 2012 | 06:55 PM
dcains's Avatar
dcains
Last pic I took - just before the explosion:
Old May 15, 2012 | 07:28 PM
realist alive's Avatar
realist alive
i hope you are joking, you do realize you probably have a better chance of the fuel pump inside of the gas tank causing an explosion then what you are talking about. look under the car there is a ground that goes from the gas tank to your exhaust, undo this ground and your gas gauge will start reading crazy results
here is my two different setups in the stock sub location, no explosions yet
Old May 15, 2012 | 07:41 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
It's safe.
I have two amps in an amp each behind the driver's side, DVD changer and XM radio control unit in the glove box, nitrous lines running through the spot behind the driver's seat, all kinds of wires running through both areas. I also had a welder weld in my cage to the floor in those areas in my roadster, I've run a cutoff/grinding wheel in those areas to cut out the sheet metal with sparks flying all over the place, etc.
You'll be fine.
/thread
m_0g
Jun 3, 2021 10:05 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
DarkCreep
Oct 17, 2015 11:50 PM
