reinstalling oem radio
im trying to reinstall the oem radio because im sick of the sony one it got replaced with. my only problems are the wiring and the mounting parts are gone. i dont have the 2 metal brackets, or the square plastic fitting that goes around the radio in the dash. the wire that plugs into the main harness besides being spliced into the sony wire plugs, has one wire cut comletely out, which makes it useless. is there a place i can by the entire 2 plugs that plug from the main car harness white plugs into the back of the radio (both ends being the male adapters)? and would it be possible to find an aftermarket set of brackets that would work with the oem radio? or am i stuck buying the oem ones?
thanks
thanks
There is a set of radio brackets listed on eBay by one of the vendors here
Just enter "350z radio brackets". Not sure what year your Z is. I am prettty sure they can get you the harness plugs as well. If you see the cut end of the wires why not reconnect them?
