Speaker Farting no bose
I noticed every single time it rains the next day i listen to music the speaker makes this weird farting sound when the bass hits. Anyone else encountered this problem before? And its only the driver side door speaker.
The speaker might be blown, or the grille may be loose. You can pop the grille off if you're careful, and see if that makes a difference. If not, then it's the speaker. Not sure what the connection to the weather is, unless the speaker is getting wet, due to water getting past the inside door seals.
If the problem only occurs after a rain storm, it must be related to moisture in the driver's side door. The stock speakers are Clarion with paper cones, making them vulnerable to moisture. --Spike
Nobody had a problem like this before?
The stock Clarion speaker is made from paper.
If moisture finds its way to this speaker, the output is “fuzzy.” You probably have a water leak that tracks along a surface allowing the speaker to get “water-logged.”
Check the driver-side window.
--Spike
--Spike
Alright thanks, the window closes all the way i know that but i will check the seals.
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
