Need help with selecting an amp.!!?
Hello,
I Recently purchased 2 Rockford Fosgate R2SD4-10 subwoofers. I don't know what is the best amplifier for this setup. Please someone help me. I left the link below so you can see the specs.
Thanks.
http://www.crutchfield.com/S-BXdCFOf...-R2SD4-10.html
Thanks.
these subs are shallow mount subs. they wont give you real lows (FR = 38-250 hz with 83 db @ 1watt) as far as an amp, look for a 2 channel 200w-400w amp (true watts not china watts), try to match your RMS from the sub to the amp. here are a few choices.
basic amp
http://www.crutchfield.com/p_575P500....html?tp=35757
recomended amp
http://www.crutchfield.com/p_575T600....html?tp=35757
basic amp
recomended amp
The Rockford Amp listed above would be more then enough powerwise. May I ask why you went with a shallow sub?
Workshop12
Mar 23, 2020 01:45 PM
