Audio help
Old Apr 10, 2013 | 03:27 PM
ag0240's Avatar
ag0240
Default Audio help
Hey guys I have a question. I have a set of alpine type r speaker with components and a set of type s speaker. I also have a 10in alpine type R sub woofer. I have and Alpine MRX-M100 amp which is a two channel amp. I cannot run the sets of speakers and the sub off that because it doesn't have enough channels correct? Does anyone kno of any good 3 or 4 channel Amps that can power the speakers and sub?
Thanks.
Old Apr 10, 2013 | 04:09 PM
Spike100's Avatar
Spike100
@ag0240… I’m not certain exactly what you are asking. If you are running a 2 channel amp, you connect this to two speakers.
If you want to power a 2 speaker-set (front left and front right), you need a 2 channel amp. If you want to power a 4 speaker set (front left, front right, rear left, and rear right), you need a 4 channel amp.
Does this make sense to you?
--Spike
Old Apr 11, 2013 | 02:25 PM
Collin Lacy's Avatar
Collin Lacy
He was asking "can I run my front speakers and sub off of this two channel sub."
Yes, dont do it. Will be ****.
I used a my NX3 works really well as a 3 channel amp. Arc makes a small one too. Pretty much any 4 channel that puts out 100 watts per channel will work, however we don't know your subs specs SVC/DVC, 2 ohm, 4 ohm (ea). how much power it needs. Are you up for using two different amps?
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
ZEyeDoc
Dec 5, 2002 03:52 AM
