Issues with installing double din in 04 350z roadster with bose 6 disc
Old May 16, 2013 | 06:17 PM
kneesonzee's Avatar
kneesonzee
Default Issues with installing double din in 04 350z roadster with bose 6 disc
Bought a Pioneer double din and what I thought was the required wiring harnesses. Only the top two are compatible. do you have to have all four of the harnesses hooked up or just the top two? All I have are the top two and nothing works. I unplugged the bottom two from the bose to try and diagnose the issue but the bose deck seems to work with the bottom two not plugged in. what gives? help me out guys...
Old May 16, 2013 | 07:58 PM
mattleegee's Avatar
mattleegee
Are you using a LOC?
Old May 19, 2013 | 01:29 PM
Fly350's Avatar
Fly350
When I installed mine it only used the top two. The instructions for mine stated this. This also means that if you have the navigation system, the voice will no longer work through the car stereo. I have not found any wiring kits that use the navigation voice plugs.
m_0g
Jun 3, 2021 10:05 AM
jlb
Oct 15, 2017 05:10 AM
416blueZ
Sep 25, 2015 10:00 AM
issyz
Sep 10, 2015 02:00 PM
