Bose Audio Upgrade? Is this worth doing
Old Jan 24, 2016 | 03:58 AM
Audionoob's Avatar
Audionoob
Default Bose Audio Upgrade? Is this worth doing
I have purchased the following headunit - Pioneer DEH X9600BT
I was originally going to use an adapter and go through the stock bose amplifier. How ever i am now contemplating buying a new amplifier and speakers if it would be worth it, if i were to do this i would want much louder audio, and just generally more crispness.
Here are the components i have looked at for the system
Headunit -Pioneer DEH X9600BT
Amplifier -Alpine F1200 4-channel power amplifier 4/3/2 channel 600 watts
Front Speakers / Tweeters - Alpine SXE-1750S 280W 17cm 2-way component speakers
Rear Speakers - Alpine SXE-1725S 220W 17cm 2-way speakers
Now my questions are the following
Firstly are these components any good? Would it be worth buying and installing all this, would it provide much louder, clearer sound over the stock system?
Would it be possible to also integrate the stock bose sub and sub amplifier in to this setup
Will the front speakers fit in the z? I have been told depth is very narrow in the z
Will 4 channels be enough for fronts and rears? Do the tweeters run on the same channel as the fronts?
Thank you
Old Jan 24, 2016 | 04:45 AM
beezee's Avatar
beezee
I can't answer some of your questions because I don't use those equipment but I can answer one. Yes it is absolutely worth it to dump the bose completely. This has been a very common question
Do a simple search with "bose " and read through some past threads. That will help you choose the correct combination of speakers and amp. I personally dumped my so called bose premium. I have 2 jl audio amps (one to power my 2 10 inch jl subs and a 4 channel one to power my jbl component speakers in the front and 2 rear speakers. However I faded out the rear speakers because they sound better to me without them.
Old Jan 24, 2016 | 08:42 AM
Spike100's Avatar
Spike100
The equipment you are considering provides better sound than the factory Bose.
Front speakers’ depth from wall is 2.4”.
4 channels will run the fronts and the rears
I doubt you want to retain the Bose SubW (even if you could)
Last edited by Spike100; Jan 24, 2016 at 10:53 AM. Reason: to add info about SubW and Amp
Old Jan 25, 2016 | 08:21 AM
JMII's Avatar
JMII
Q: Firstly are these components any good?
Yes those are all decent.
Q: Would it be worth buying and installing all this, would it provide much louder, clearer sound over the stock system?
A: Anything is better then stock.
Q: Would it be possible to also integrate the stock bose sub and sub amplifier in to this setup
A: You could, but it wouldn't be worth it, better off going all aftermarket and "doing it right".
Q: Will 4 channels be enough for fronts and rears? Do the tweeters run on the same channel as the fronts?
A: 4 channels can either be split Front / Rear or Highs (Treble) / Lows (Bass). For good front sound stage I wouldn't bother with the rears. Instead I'd run components up front (not 2 ways) and bridged the amp (into 3 way mode) to a different sub.
Dallasmavs92
Jan 19, 2016 11:41 PM
Cbrrida
Brakes
Jan 18, 2016 09:22 AM
