HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install
Old Mar 9, 2004 | 08:52 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Default HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install
OK i had some fun this past weekend and took out just about every interior panel on my car. I have factory Navigation as well.
Components:
Head Unit - Alpine CDA-7998
Front Speakers - MB Quart RCE-216 6.5" Component Set (separates)
Amplifier - JL AUDIO 500/5 5 Channel Amp
DVD Player - POWER ACOUSTIK DVD 35
TV Tuner - Navigation TV Tuner System from AVElectronic
Video Game - XBOX
XM – Alpine TUA-T020XM
Sub Woofer – 1 JL Audio 10w6v2 with box
Miscellanies parts:
100’ Fat Mat
XM antenna
Diversity Antenna for Local TV channels
Power Inverter
Alpine KCA-121B (Male Right Angle Ai-Net to Female RCA Cable)
Bass Control ****
Metra Dash Kit #99-7402
2 6 inch Neon Red Tubes
3 Four Point Relays
3 30 Amp glass Fuses
10’ Red Power wire
3’ Ground Wire
2 gold plated rings connectors with shrink tube
1 to 2 Fuse Block
Fuse Block
Wire Divider for three connections
Stock Stereo Plug Adapter
2 sets of RCAs Monster Power 8 feet
1 set RCAs 3 feet
1 component Video/Sound RCA
40’ Speaker Wire
Liquid Nails
3 inch speaker
Banana Plug
Sounds great. I have to cut one additional wire this weekend to fix the vidoe sync. Appartenly there is one extra sync wire on my screen. Nissan has installed two different screens. It was to pin 14 on the navigation plug. I did buy a cheap box for the sub now and will do a custom panel to cover the amp in the next couple of weeks. I have not installed a custom box yet as I ran out of money however I think it will go under the strut bar or to the side of the spare in the trunk.
What do you think?
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-install_stereo.jpg
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-hu.jpg
Old Mar 9, 2004 | 08:53 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-amp.jpg
Old Mar 9, 2004 | 08:54 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-mbquarts.jpg
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-fatmat.jpg
Old Mar 9, 2004 | 01:14 PM
liptonme's Avatar
liptonme
dedication.....
Old Mar 9, 2004 | 03:09 PM
Fuddy's Avatar
Fuddy
Must be nice to have your own garage!
Old Mar 9, 2004 | 04:39 PM
Bini2's Avatar
Bini2
Nice! I didn't see the XBox, where did you put that?
Old Mar 9, 2004 | 07:24 PM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
It is in the glove box. The inverter is installed behind the glove box with a cutout for the two plugs and the switch. The Tv tuner is mounted underneath along with the fuse block. It was raining today so I did not get some more pics. Maybe tomorrow.
The bass control is in the switch plate next to the VDC. The video screen switch is installed in the front of the center console pocket. The IR eyes are installed on the passenger side a-pillar.
Old Mar 9, 2004 | 07:25 PM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Attached Thumbnails HU, XM, Amp, DVD, TV Tuner, Xbox, Sub, Speaker install-sub.jpg
Old Mar 9, 2004 | 09:16 PM
jerrera350's Avatar
jerrera350
That is an awesome setup....Props...!
Old Mar 9, 2004 | 10:28 PM
CatastrophZZ's Avatar
CatastrophZZ
are those dynamats? or stock... 'duct' tapes? LOL. cuz they're just in small pieces and in random places. like 4 on the rear strut bar. same for the door. just wondering...
Old Mar 10, 2004 | 08:01 AM
D@ActiveTuning's Avatar
D@ActiveTuning
Looking good so far! Post more pics! Like the mounted switches, xbox, anything else.
Old Mar 10, 2004 | 08:15 AM
toykilla's Avatar
toykilla
GOOD JOB SO FAR.. DO SOMETHING WITH THAT SUB BOX AND YOU HAVE A PRETTY SWEET SETUP..
Old Mar 10, 2004 | 08:30 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Fat Mat. Cut and placed everwhere possible where it did not cover clip or screw holes.
Old Mar 10, 2004 | 08:32 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Thanks! Yeah, I wish I had the money to finish. I will have it nailed down by the end of the summer. The box only cost me $100 and I would rather get the better sub and wait for the box. I go to the track 5 times a year so it will be easy to remove for now.
Old Mar 10, 2004 | 08:56 AM
CatastrophZZ
another question if you dont mind... is that aftermarket speakers or stock? cuz they look like stock cheap paper speakers. in my '02 Celica, it has almost the same speakers set up as the Z. it has a big base i guess that's b/c of the magnet that's too deep inside the door panel or something... but my question is, when you're replacing it with an aftermarket speakers do you just remove the speakers itself or the base of it as well?
tnx!
Old Mar 10, 2004 | 09:50 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Aftermarket MB Quarts. Remove the entire speaker including the magnet. wood was used to recreate the stock spacern that was part of the orginal speaker. The spacer is used to mount the speaker out a little so the window does not hit it.
Old Mar 10, 2004 | 12:40 PM
Natal's Avatar
Natal
Please post some pictures of your AVElectronic Navigation Tuner System installation.
I'm also interested in the video sync problem; didn't know they had two different screens on the 2003. I'm guessing you spliced your AVElectronic system wires directly to the output of the Nav system, since they don't have an adapter, or were you able to use part of the connector?
Old Mar 10, 2004 | 12:43 PM
Natal's Avatar
Natal
Sorry -- deleted duplicate post.
