I may never have the fastest Z...
Old Mar 10, 2004 | 06:02 PM
ares's Avatar
ares
Veteran
Default I may never have the fastest Z...
but after 1 year I may have the fastest Z PC.
sadly its become dated before it was even installed. started this project 1 year ago exactly, and due to a bum touch screen that took 7 months to repair, it never got installed.
but now it has(FM transmittor and DVD drive all that are left to be installed)
system specs are as follows
Asus nForce 2 mobo
1600+ (1.2ghz) AMD athlon
512mb memory
integrated Gforce 4 MX (8xAGP slot open)
40gig HD
DVD rom
Xenarc VGA touch screen
total cost of that was about 1100$(all purchased a year ago, hence the high prices)
on top of that, I built a custom PC case from aluminum L bars and diamond plate, only way to fit a full size ATX MOBO in the glove box with room to spare.
cool thing is, its totally upgradable. in that I mean take ANY PC you might possibly be running right now, and itd fit in there. I have 4 unused PCI slots, USB ports ect ect.
owell, picture time
Old Mar 10, 2004 | 06:06 PM
2003z's Avatar
2003z
sweet, can't wait to check it out this weekend!
Old Mar 11, 2004 | 07:45 AM
stopgo's Avatar
stopgo
Ares,
You gonna be at the Evolution meet this weekend? If so, I'd like to see your set-up. I've got an unused laptop that I've been considering using for a similar purpose.
Scott
Old Mar 11, 2004 | 09:54 AM
CatastrophZZ's Avatar
CatastrophZZ
home made case? cuz it looks like a bunch of alluminum bars putting together...
Old Mar 11, 2004 | 10:00 AM
ares's Avatar
ares
Veteran
it is just that. light weight and super small. exactly as large as it needs to be. a normal tower case would never fit
ares's Avatar
ares
Veteran
dont think Im going to the evolution meet, going to 2003Z's meet though
Old Mar 11, 2004 | 03:41 PM
ares's Avatar
ares
Veteran
eh the modulator is giving me sh*t. anyone else here deal with the whole inverter+modulator issue?
I know I need to rework the grounding, sketchy on the details, if anyone knows what Im missing give me a PM.
Old Mar 11, 2004 | 11:22 PM
aalzuhair's Avatar
aalzuhair
ares,
Is the HD working fine for you, being a desktop HD not a laptop HD?
I have the same screen setup but I'm still think about the PC
Az
Old Mar 12, 2004 | 07:08 AM
ares's Avatar
ares
Veteran
well its been in the car for a year, the whole PC has, its lived through bumps that my rims didnt live through. the boards took 120degree summer heat, and it all runs fine.
but it wasnt ON for any of that of course.
if you designing it now, lay the harddrive vertical, I didnt and that may be a problem. supposedly these guys are more resiliant than many think. theres also a hard drive suspension thing that somebody on mp3car found, with that and vertical mount, it should be fine.
Old Mar 12, 2004 | 03:27 PM
alphared's Avatar
alphared
I wouldn't suggest vertical mount. Yes you can prevent head crash (the disks touching when you hit a bump) Vertical mount can cause the read head & arm to scratch the disk.
Think of a old LP turntable. The read head is the needle and the LP is the disk. Mount it vertical and the arm will oscillate with the bump (ie Taking the needle and moving it back and forth over the LP)
I think someone had a problem where the arm was too heavy and that the vertical mount restrict the arm to move up and read the disk.
Old Mar 12, 2004 | 03:49 PM
alphared's Avatar
alphared
This was a shock protector that someone posted.
Here
Old Mar 12, 2004 | 03:59 PM
aalzuhair's Avatar
aalzuhair
Thanks guys,
I was assembling my Z pc today, but it did not work, I guess my windows XP CD is screwed up or something,
Do you guys know if it is possible to hook up a laptop HD to a normal desktop mother board?
Thank you,
Az
Old Mar 12, 2004 | 04:20 PM
2003z's Avatar
2003z
why not just stick a laptop in the glove box, with an aux keyboard, mouse and video out to the nav screen?
Old Mar 12, 2004 | 04:28 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Or why not just do this:
http://www.350zfrenzy.com/forum/show...&threadid=1386
http://www.350zfrenzy.com/forum/show...&threadid=1403
Old Mar 12, 2004 | 04:42 PM
Bini2's Avatar
Bini2
Thank you,
Az
Sure is, I have used these before:
http://shop.store.yahoo.com/laptopsf...o35laphar.html
Old Mar 12, 2004 | 05:40 PM
ares's Avatar
ares
Veteran
yeah, I tried it, and there is an adaptor for it, didnt work for me... but apparently thats not the norm(as I said, nothing worked for me in this project.)
I ended up just thinking, these regular HD's are half the price, twice the space, twice the speed, and for what? not like a laptop is intended to be thrown around either... though they are low power comsumption which is important for the DC-DC guys. I got 300watts at my disposal. may as well enjoy em.
anyway, the FM modulator is screwed, and I gave up on it. went to microcenter and got the belkin transmittor II, it has the ability to transmit at any and all stations at a .1 interval. works on batterys(though in the future it takes straight 12v in, so Ill work that out), and got no inverter feedback at all.
problem solved, just printing out the shift boot install as I type this, so I can do that while its out. and put her back together.
next weekend I need to make a mounting plate for the mailbox slot where a powered USB hub and DVD rom will sit.
Vad
Feb 6, 2003 10:41 AM
Emax02
Nov 18, 2002 06:46 PM
PhoenixINX
Oct 28, 2002 06:40 PM
Scourge
Oct 18, 2002 03:45 PM
