Amps --> 2 ohm vs. 4 ohm
Old Mar 14, 2004 | 06:34 AM
zachcrosen's Avatar
zachcrosen
Default Amps --> 2 ohm vs. 4 ohm
Can someone explain the difference in hooking an amp up in 2 ohms vs. hooking it up in 4 ohms. I know 2 ohms produces more power, but how is it hooked up any differently than if it were in 4 ohms? Also, are Infinity Kappa 60.5cs and 62.5i's 2 ohm stable? Thanks
Old Mar 15, 2004 | 11:57 AM
wesleyvt's Avatar
wesleyvt
Default Re: Amps --> 2 ohm vs. 4 ohm
To use the amp as 2ohm, you need to hook up TWO 4ohm speakers in parallel (+ to + and - to -). This setup is used typically for powering two subs. The box should tell you if the speakers are 2 ohm stable, but like i said the 2 ohm setup is really for subs since they only use one channel (no front/rear - left/right).
m_0g
Jun 3, 2021 10:05 AM
kyin
Oct 15, 2015 05:54 AM
_koubie_
Sep 20, 2015 06:34 PM
