Can you hook up sat radio thru stock head unit ?
Old Apr 12, 2004 | 09:08 PM
bswanny's Avatar
bswanny
Default Can you hook up sat radio thru stock head unit ?
Is their any way to hook up satilite radio on the stock head unit if that option was not choosen? Their is a button on the stock unit for it. I was just wondering if anyone knew anything about this. Thanks for the help.
Old Apr 13, 2004 | 02:54 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I'm not sure exactly what you mean, but most sat. radios installed aftermarket (mine included) run through the stock HU via an FM modulator. In other words, you tune your FM radio to a certain channel and the XM radio plays through it. You adjust volume, base, treble etc on your HU.
Old Apr 13, 2004 | 03:53 AM
mgk65's Avatar
mgk65
I take it you have a 2004?
You'll need a sat radio wiring harness and a Nissan XM tuner. Contact http://www.infinitiwholesaleparts.com/en_US/ for good prices on that set up. It will be several hundred dollars, but will be fully integrated.
If you want to go less expensive, the XM Commander or Roady or SkyFi all have FM Modulators that plug into the antenna and you then tune to an FM channel to hear the Sat Radio.
Old Apr 13, 2004 | 07:14 PM
bswanny's Avatar
bswanny
Yeah, its a 2004. Thanks for help and tips.
Old Apr 14, 2004 | 10:45 AM
Norel350Z's Avatar
Norel350Z
do those adaptors work for just the bose, or the none bose too?
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
