NEED HELP ASAP! Where did you mount your crossover?
Old Apr 22, 2004 | 01:29 PM
D@ActiveTuning's Avatar
D@ActiveTuning
Default NEED HELP ASAP! Where did you mount your crossover?
I'm installing Infinity Kappa Perfect's...where did you guys mount your crossover?
Old Apr 22, 2004 | 02:14 PM
zachcrosen's Avatar
zachcrosen
I have a set of Infinity Kappa 60.5cs components and I mounted my crossover in the secret compartment in the glove box.
Old Apr 22, 2004 | 02:25 PM
D@ActiveTuning
How did you run the wires from the inside of the car to the door then?? Because there's a plug...not just a regular grommet..
Old Apr 22, 2004 | 02:29 PM
zachcrosen's Avatar
zachcrosen
I took it to a local installer and they did the work for me. They had to take and drill out the plug so that wires would fit thru it. There are 2 sets of wires that run thru my harness plug; one is 16 gauge and the other is 12 gauge. If the search thing is working, do a search and you should find some pix of what it is supposed to look like. Wait, i think there are instructions under the "how to" thread. Hope this helps.
Old Apr 23, 2004 | 11:48 AM
veddic's Avatar
veddic
Check this thread out, it has how to's on just about everything including running wires into the doors.
350Z How To's
Old Apr 23, 2004 | 12:36 PM
Big Sexz's Avatar
Big Sexz
Put some bubble wrap around them and then wrap them win the plastic bags they were shipped in and stuff those puppys in the door. That way they are out of the way and water cant get to them. Are you trying to run those with the factory wire? Are you using an amp?
Old Apr 23, 2004 | 02:05 PM
D@ActiveTuning
^^ Thanks, that's what I did I'm using factory wire for now, but I want when I install the amp, I'll be running 12 guage all through the car.
Old Apr 23, 2004 | 09:18 PM
chaparro78's Avatar
chaparro78
just keep the crossovers in the doors
Attached Thumbnails NEED HELP ASAP!  Where did you mount your crossover?-100_0100.jpg
Old Apr 24, 2004 | 03:50 AM
hndumafia's Avatar
hndumafia
ive got my cross overs in the secret compartment and then two 12 gauge going to each door. it's probably easier to keep the cross overs in the doors because you only have to run 1 wire into the door then. and the less wires you have to run into the door the better...that was my least favorite part of the install.
Rajiv
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
