Stupid dynamat question
Old Apr 24, 2004 | 10:56 AM
Dissident's Avatar
Dissident
Default Stupid dynamat question
So, those of you that have used sound proffing material in your Z, how do you deal with holes for screws and clips and stuff? Do you just poke a hole through the material, or do you cut, or what? I'm about to start soo, and I have no idea.
Old Apr 24, 2004 | 11:41 AM
alphared's Avatar
alphared
Default Re: Stupid dynamat question
Depends on the size of the hole. I just used a screwdrive to punch an hole for the screw or clip. Or use the blade to do a 'X' mark. It does make putting the screw/clip back in harder since there's extra material near the hole, but just think of it as extra grip
Old Apr 24, 2004 | 08:14 PM
Th3Cleaner's Avatar
Th3Cleaner
I cut a circle around the clip hole, and cover all others up, to a degree.
Old Apr 25, 2004 | 08:49 AM
ZNizzy's Avatar
ZNizzy
Cutting a hole in the Dynamat to get to a clip or screw won't make any difference in the sound quality unless the screw or clip is loose. Save your self a hassle later and cut out a hole.
Old Apr 26, 2004 | 03:54 AM
hndumafia's Avatar
hndumafia
How do the panels fit back in place over the dynamat? It's kinda thick and i didn't think there was that much space between the panels and the metal. But i guess i'm just wrong?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
