G35 Nav to play DVDs?
Old Apr 26, 2004 | 03:47 AM
703z's Avatar
703z
Default G35 Nav to play DVDs?
Someone told me there is a way to let the Nav DVD player. play regular DVD movies and such?
Or is there some kind of panel that will let you change the bose head unit to buy a aftermarket DVD player?
Old Apr 26, 2004 | 04:42 AM
NismoKid's Avatar
NismoKid
The US doesn't allow factory vehicles to be equppied with a DVD player that can be used (to watch movies) while the car is in motion. I'm sure you could find a way to make it work, but it would be easier to not get the NAV and get an aftermarket screen with the things you want.
Old Apr 26, 2004 | 05:12 AM
703z's Avatar
703z
yeah i wanted to get a aftermarket setup, but the stereo on the G35 is like built into the whole console. you cant just take the stereo out and pop in a DVD player. so im kinda stuck =/
Old Apr 26, 2004 | 08:11 AM
703z's Avatar
703z
Found a place called AV electronics that sells a adaptor that lets you play DVDs on Nav player for around $500. www.AVelectronic.com
Does anyone know how i can change the head unit on my G35? it isnt a normal head unit you can pull out and put another in, its like built into the whole console.
Old Apr 26, 2004 | 02:40 PM
Tekwon-V's Avatar
Tekwon-V
Originally posted by 703z
[B]Found a place called AV electronics that sells a adaptor that lets you play DVDs on Nav player for around $500. www.AVelectronic.com
i browsed around the website... this module... does it need a separate dvd player to get the movies goin?
in other words... .can the dvd 'player' that 'plays' navigation system be used to play the dvd movie?
Old Apr 26, 2004 | 10:32 PM
jeffa's Avatar
jeffa
The Navi DVD in the G35 (and the 350Z) cannot read a video DVD, it can oly read data DVD's that contain mapping information. There is no kit or reprogramming of the DVD mech that will allow it to play DVD's.
The kit from AV Electronics requires a separate DVD player for DVD video playback.
As to the removal of the factory head unit, it can be done, but you will need to find someone with contacts in Japan. There is an aftermarket adapter kit that allows an double DIN or a single DIN chassis radio's to be installed. However, this kit is expensive, between 150 and 200 dollars US (if you can find one).
Hope this helps...
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
