What Components Are You Using In The Doors?
Old Apr 28, 2004 | 11:06 PM
chaparro78's Avatar
chaparro78
in the door
Attached Thumbnails What Components Are You Using In The Doors?-100_0100.jpg
Old Apr 29, 2004 | 06:45 AM
jhchan's Avatar
jhchan
Give the Kendwood eXcelon 6.5" a try. They are supposed to be shallow enough to mount with no mods. I have them but are not intalled yet. Another couple guys on the forums have installed them with no mods needed.
Old Apr 29, 2004 | 02:32 PM
Bertg's Avatar
Bertg
I have the Focal Polyglass 165 V Slim in the doors. They sound awesome!
Old Apr 29, 2004 | 09:37 PM
big-al's Avatar
big-al
Default door speakers???
heres a layout of my speakers......
stock speakers in the door (for navigation)
rear speaker are empty storage compartments w/detachable grill.
HIGHS:
a pair of ILLUSION AUDIO CH1 (compressed horns)
under each side of dash.
MIDS:
custom kick panels w/FOCAL UTOPIA 165W (6.5") driver. kick panel metal reinforcements (fenderwall) was removed, recessed and rewelded, also relocated fuse box, clutch switch, multiplex modules, wires, etc. to accomadate fiberglass kick pods.
LOWS:
in the bottom(floor) are 4-ILLUSION AUDIO Nd8 (8")drivers, 1 under each floormats and another under each seat (seats were raised 1/2" only to accomadate)
ULTRA LOWS:
and in the trunk is a 15" ILLUSION AUDIO Nd15, playing below 43Hz, since sub is only 4.75" depth, box was at stock height.
did i mention the 1/2 ton of DYNAMAT!!!
Attached Thumbnails What Components Are You Using In The Doors?-inside-full.jpg
Old Apr 29, 2004 | 09:39 PM
big-al's Avatar
big-al
Default more pics
kicks
Attached Thumbnails What Components Are You Using In The Doors?-left-side.jpg
Old Apr 29, 2004 | 09:40 PM
big-al's Avatar
big-al
Default more pics....
kick and horns
Old Apr 29, 2004 | 09:42 PM
big-al's Avatar
big-al
Default mo pics
floor subs...
Attached Thumbnails What Components Are You Using In The Doors?-dsc00587.jpg
Old Apr 29, 2004 | 09:43 PM
big-al's Avatar
big-al
Default floor subs again
floor subs from away
Attached Thumbnails What Components Are You Using In The Doors?-dsc00594.jpg
Old Apr 29, 2004 | 10:03 PM
big-al's Avatar
big-al
Default last one...
the trunk.......this the only pic i got ..
Attached Thumbnails What Components Are You Using In The Doors?-dsc01609.jpg
Old Apr 29, 2004 | 10:43 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
love that set up al... im jealous as f&*K...
someday...
Old Apr 30, 2004 | 07:05 AM
zblue70's Avatar
zblue70
I'm running Phoenix Gold Titanium Elite TI6Comp components. They sound incredible, and I can't believe they amount of bass they produce with my amp powered to then.
Old Apr 30, 2004 | 07:43 AM
big-al's Avatar
big-al
Default one last pic
sorry, dont ment to hog up this thread but i got one last pic.....
Attached Thumbnails What Components Are You Using In The Doors?-dsc02100.jpg
Old Apr 30, 2004 | 09:00 PM
JimRHIT's Avatar
JimRHIT
Klipsch 6.5" Cerametallic mids in the doors
Klipsch tractrix horns from a RCW-3 molded into the kicks
modded xo from the rcws ...
I had to make a MDF ring to mount the mids ... so they are spaced out a bit.
I was suprised at how little room we have to work in there.
As long as you are installing yourself ... just get creative .. you can make it fit.
Al,
Very nice install ... how did you get the nd-8s in the floor?
Is that the Pioneer premier 9?
Are you using its internal crossovers for the front 3-way setup?
jim
Old Apr 30, 2004 | 10:32 PM
big-al's Avatar
big-al
Al,
jim
the Nd-8 are only 2" deep, so floor level wasnt raised up at all, i took out all cushon under oem carpet then replace with MDF/fiberglass, made sealed encolsures. seat was raised 1/2 to clear rails.
the P9 has built-in 4way electronic x-overs/time align.
Old May 1, 2004 | 08:50 AM
JimRHIT's Avatar
JimRHIT
Al,
Are you the same Audiomobile that used to be run by matt overpeck? (EVO, MASS, NICHE subs)
Or is that just your shop name?
Jim
Old May 1, 2004 | 09:17 PM
big-al's Avatar
big-al
Default not the same AUDIOMOBILE
we are in bay area since 1990, used to have 4-store chain.
1. SAN JOSE
2. CAMPBELL
3. MOUNTAIN VIEW
4. OAKLAND
now its just Oakland.
Old May 2, 2004 | 07:51 AM
ZNizzy's Avatar
ZNizzy
I'm running the PCE216's and didn't have any problems. I had the stereo shop do the install but I'm sure that they would have charged if they had to make any modifications. 6.5 in the door and the tweeter in the stock location. They mounted the crossovers under the seats because it was closer to the amp and you want to get as little exposure to heat and moisture as possible.
Old May 2, 2004 | 09:17 AM
  #38
TXSTYLE's Avatar
TXSTYLE
Thanks for all the hijacks... I mean replies. I have all my speakers selected.
Now............ The saga begins......... The Audience Is Listening!
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Mikey R6
Sep 19, 2015 01:48 AM
roadmax
Sep 12, 2015 05:55 PM
