Audio experts - need advice
Old Apr 28, 2004 | 09:32 AM
gringott's Avatar
gringott
Question Audio experts - need advice
I have installed my WX-7700MDX. I have yet to install the speakers, Kappa 60.5CS componets for the doors and Kappa 62.5I for the rear, as well as a Basslink. I am held up by going krazy trying to choose an amplifier.
My budget is the $150 price range. Don't need huge power, rather have clean sound and TRUE rms power.
Things making me krazy:
Should I just get a two channel amp for the front, and let the head unit power the rear speakers? If so, which amp?
Or should I get a multi (four channel) amp to power all four? If so, which amp?
Or should I get two two channel amps, 1 for the front, one for the rear? If so, which amps?
The head unit has 5.5v RCA preouts.
Thanks for your help.
Old May 2, 2004 | 08:06 AM
ZNizzy's Avatar
ZNizzy
Default Re: Audio experts - need advice
I was in the same boat. I ended up getting a 4 channel amp, in case I changed my mind later, bridged it to 2 channels and did my fronts first. It sounded fine so I left the stock in the rear powered by my deck. They are attenuated so much already that they are just rear fill. If I ever change my mind I can drop new ones in the rear and then use all 4 channels on the amp. Problem solved.
Old May 2, 2004 | 10:36 AM
gringott's Avatar
gringott
Default Thanks, I bought a 4 channel
and decided to do the same as you. Thanks for your input.
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
