10" Infinity Sub in stock location
Old May 3, 2004 | 04:10 PM
bshockley's Avatar
bshockley
Default 10" Infinity Sub in stock location
So, I trial fitted my Infinity Perfect 10.1 and she doesn't fit directly in there. Does anybody know of an adapter to fit her in there with? I looked on the factory BOSE sub and didn't find anything.
Old May 3, 2004 | 04:23 PM
AndyB's Avatar
AndyB
Default problem
Depends on the problem.
Is it just that the bolt holes don't line up? If so, can't you just drill more holes?
Old May 3, 2004 | 04:31 PM
SQUILL's Avatar
SQUILL
Default Re: 10" Infinity Sub in stock location
woah !!!Time out!! that factory location isnt sealed properly to run a good sub in you will need to build an enclousure or else that infinity sub will be running free air and will sound like crap!!!!!
Old May 3, 2004 | 05:02 PM
bshockley's Avatar
bshockley
I know that I need an enclosure, which I will make to fit in the stock location. I also know there are better locations than back there.
In the interim I want to just place it in the stock location. Then, I will put in a box or find a way to seal that area.
I don't want to take up what little room I have in the truck/hatch area, and I really want to keep everything stock looking.
That being said, it is just a little too small for the opening. So, none of the holes line up. I was hoping someone else has done this and knew of a cheap mount.
Old May 3, 2004 | 05:16 PM
SQUILL's Avatar
SQUILL
Every install ive seen they have taken out the stock metal sub box panel that the bose sits in and built a box in that location and then throw the plastic back on so you keep the factory look.
Old May 4, 2004 | 01:25 PM
desiZ's Avatar
desiZ
do u have a link to a thread that shows where / how to make one for the infinity basslink sub ?
Old May 5, 2004 | 03:23 AM
AndyB's Avatar
AndyB
Default Basslink
The basslink is a sub, amp, and enclosure in one. It doesn't need any additional enclosure. That is one of the things that makes the basslink a bargain. (enclosures ain't cheap)
You can see my basslink mounted in the stock location here:
My Install Pics
Old May 5, 2004 | 07:14 AM
JasZ's Avatar
JasZ
I am building an enclosure for the stock location. Do I need to Dynomat the stock area, or will the enclosure take care of it?
Old May 6, 2004 | 04:54 AM
240DRIVEN's Avatar
240DRIVEN
Default you don't have to put a box back there
https://my350z.com/forum/showthread....threadid=69818
Old May 6, 2004 | 12:03 PM
AndyB's Avatar
AndyB
Default dynamat
If you are running a sub in it's own enclosure you only need dynamat to reduce road noise or prevent rattles.
Old May 6, 2004 | 02:09 PM
SQUILL's Avatar
SQUILL
Sorry for the delayed response but i thought you were putting a 10 " sub back there that needed an enclousure. the infinity basslink is its own self amplified enclousure and doesnt need a box built for it..
On a second note i think the basslink may be too big for that location however if it isnt then i guess just throw some dynamat in there and call it good!
Old May 6, 2004 | 03:22 PM
desiZ's Avatar
desiZ
kewl thanks andyB & Squill !!
sales@czp
Sep 23, 2019 03:30 PM
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
