Valentine Radar
Old May 29, 2004 | 03:59 PM
311roadster's Avatar
311roadster
Post Valentine Radar
I purchased a new Valentine V1 detecter (still in the 30 day trial period) and I am having problems with it since the suction cups keep falling off the windshield. Anyone else have this problem?
Thanks
Old May 29, 2004 | 04:25 PM
cwerdna's Avatar
cwerdna
Default Re: Valentine Radar
I've had a Valentine One for many years and I had that prob too. I stopped using the suction cup bracket and just use the visor bracket. The repeated falling down caused cracks in the top of the dash of my old car (91 Camry V6).
Old May 29, 2004 | 04:43 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Wet them a little bit and they shouldn't fall down. I actually have a small drop of super glue inside mine and it'e been there for 20 months and has never fallen down.
Old May 29, 2004 | 05:51 PM
overlord tom's Avatar
overlord tom
A drop of vegetable oil in each suction cup works wonders since it doesn't evaporate.
Old May 29, 2004 | 10:40 PM
Silverstone_350's Avatar
Silverstone_350
It's been a while since I had a V1 in my car so I don't really remember, but wouldn't a visor bracket be too high for the V1 to be effective?
Old May 30, 2004 | 03:40 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
a little piece fell out of my v1's power cord and into the outlet and now neither my v1 or my outlet work =/
Old May 30, 2004 | 05:02 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Did you get the piece out? Did you check your cig. lighter fuse?
Old May 30, 2004 | 10:59 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
No I cant get the piece out i tried and ended up letting it slip through the hole =/..and I havn't checked the fuse but 90% chance of that being the fix, also need to call about the part for the radar again b.c. they sent me the wrong one. How do I go about changing that fuse? thanks
Old May 30, 2004 | 01:09 PM
jj1814's Avatar
jj1814
I've been using the suction cups since I got the V1 last summer, and I havent had a problem w/ them. The V1 has been up in my winshield since I initially installed it, since it is hardwired.
Old May 30, 2004 | 02:02 PM
Richardew's Avatar
Richardew
I use a "stick pad" on the dashboard. Radar is illegal in VA, but I find it very helpful. I have to be able to hide it quickly. So far, in 12 years of using radar in VA, I have only been cought with it once. The trooper was just setting up and didn't have his radar on yet so I didn't know that he was hiding in the median. The dude had great eyesight though and was very nice about it. Good luck with your V1 and your Z.
rich
Old May 30, 2004 | 02:40 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
The fuse box is just to the left of your left foot if you are sitting in the driver's seat. Just pop off the black plastic cover and look for the fuse for your cig. lighter. Pull it out and replace it with another one.
Old May 31, 2004 | 05:41 AM
Richardew's Avatar
Richardew
Here is a pic of the sticky pad ad. I got mine from Best Buy. This pic is from Compusa. Any store with a lot of cell phone accessories probably carries it.
rich
Old May 31, 2004 | 05:57 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I suppose for your needs that would be good but any detector will lose some of its range and effectiveness down there as opposed to up high on the windshield. The higher the better when it comes to range.
Old May 31, 2004 | 07:00 PM
duger's Avatar
duger
i am currently considering that exact purchase, although 400 is a steep price, do you guys think its worth it?
Old May 31, 2004 | 07:05 PM
SHO-TIME's Avatar
SHO-TIME
Suction cups are fine with me.
You just have to clean the surface (windshield) very well before you try attaching them. Also, moist the suction cups too. I never really had to use any other than water to hold it up there. I've had the V1 for 6 years (2 years in my Honda Prelude, 3 years in my Acura TL, 1 year in my Z) still using the same suction cups and and they are holding pretty well.
Old Oct 15, 2009 | 04:37 PM
mariannessmith@'s Avatar
mariannessmith@
I've bought a bracket for mounting the v1 on the rear view mirror and I want to hard wire the unit into wiring coming out of the headliner in the area of the interior lights. I dont think I should use the interior light 12V because its on (the 12v) all the time. Any suggestions? Will I have to run ground and 12v line all the way down through the window pillar into the fuse box? If so has anyone tried this? Any suggestions?
Smith in Texas
Old Oct 15, 2009 | 05:10 PM
dhays's Avatar
dhays
Smith in Texas
The V1 is great and if you bought the mount that MIKE3348 makes then that is a very high quality mount.
The best way to wire it, if you have the powered mirror, is to use a chord from Invisichord. It works great and makes for a very easy and clean install.
The other option besides using the rear view mirror mount, is to mount the V1 to the headliner behind the passengers left ear. Do a search for stealth V1 install and you should find several threads. I did this myself and really like it. I just used the visor clip that came with the V1, took off the spring clip, drilled a hole in the holder, and used the headliner trim fastener to attach the V1 to the headliner. It works great, is out of the way, and simply can't be seen from outside the car. I wired the V1 remote later and now have it velcroed to the front windshield.
Rear views
Front views
Remote display
Old Oct 15, 2009 | 06:04 PM
3oozx's Avatar
3oozx
I like the visor set up but I have also had problems with the suction cups as well in my z32 and now my 350z I just bought new suction cups it hasnt fallen yet so
Old Oct 16, 2009 | 06:59 PM
mariannessmith@
Default valentine install
dhays,
Thats a very sanitary installation on your detector. Thanks for the input.
Smith in Texas
FastEddie73
Mar 2, 2003 08:02 AM
FastEddie73
Mar 1, 2003 10:42 AM
FastEddie73
Mar 1, 2003 05:56 AM
gstdtim
Nov 12, 2002 10:18 PM
