Question for those with amps in the area designed for the factory sub.
Old May 30, 2004 | 06:32 PM
done12many2's Avatar
done12many2
Default Question for those with amps in the area designed for the factory sub.
For those of you that have installed your amps behind the seat in the location of where the factory sub goes, what is your grounding point? I have found two large bolts back there that seem to be ideal for a ground. Was planning on removing the nut and sanding down the paint with a Dremel. Then running a 0 gauge wire to a ground block and then 8 guage to my two smaller amps which will be about a 1 to 1 1/2 foot run for each. I will be running a 4 gauge to the large amp which is going to be installed to the rear of the rear speakers in the space between the rear strut bar and the rear speakers. If you agree with this or have used something else that you found to be a better ground, please let me know. Thanks in advance!
Old May 30, 2004 | 06:41 PM
done12many2
Here is a pic of the bolts that I was considering.
Attached Thumbnails Question for those with amps in the area designed for the factory sub.-ground-point.jpg
Old May 31, 2004 | 01:14 AM
MonkeyBoy's Avatar
MonkeyBoy
Mine was on the side of the car next to the door. I wish I had a digital camera to show you. Essentially, it is on the frame where the sub cover bolts on to the right under the side trim panels. There are two gaps where you can run wire to hook it up there.
Old May 31, 2004 | 05:53 AM
thadon's Avatar
thadon
A ground is a ground. Essentially their are other places on the chassis to connect the ground wire but the two bolts that you uncovered should do the job!
I was wondering though if you have the factory bose system? I am asking because I have the base model Z hence no sub enclosure. I also planed on installing my amp in the same location. I was kind of worried about the heat generated from the sub and if it would be a problem if the area was not vented.
Old May 31, 2004 | 07:46 AM
MIAPLAYA's Avatar
MIAPLAYA
What you have in mind will work just fine. Same here.
Old May 31, 2004 | 07:47 AM
MSGarrett1's Avatar
MSGarrett1
I have my JL 500/5 in that location. thadon . . . I have had no problems with the amp overheating, even though that area is not directly ventilated. However, I'm not sure what you mean by the sub generating heat. If your sub is in that location, then how can you fit your amp there?
done12many2 . . . that ground should be fine.
Old May 31, 2004 | 07:52 AM
done12many2
I talked to my Zapco dealer about mounting the amps in there and he said that they would be perfectly fine. I don't know if you have seen the Reference series Zapco amps, but they are half amp/half heat sink. They usually stay really cool under just about any condition. I'll have pics of them mounted in there when I get done building the false floor and amp rack to mount them on.
Old May 31, 2004 | 07:54 AM
MIAPLAYA's Avatar
MIAPLAYA
I have a JL 250/1 and a ALpine MRV-F340 there and have had ZERO heat issues. That includes a recent road trip to Palm Springs. Pounding the whole way.
Pics:
Old May 31, 2004 | 08:21 AM
zand02max's Avatar
zand02max
I have a Pyle 3-Farad Cap, Rockford Fosgate Power 1000 and Power 800.4.
No problems with heat so far.
Attached Thumbnails Question for those with amps in the area designed for the factory sub.-imgp1650.jpg
Old May 31, 2004 | 12:30 PM
thadon's Avatar
thadon
Typo on my part. I was referring to just having an amp mounted in their.
Thanks for answering my question!
Old Jun 1, 2004 | 02:44 PM
Blue Liquid's Avatar
Blue Liquid
zand02max, how did you secure the wooden things that the amp is bolted to? Does it move? Is there anybody local to me who has done this?
Old Jun 1, 2004 | 02:50 PM
zand02max's Avatar
zand02max
Its screwed to the frame, doesn't move at all.
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
