Something is killing my ears
Old Jun 18, 2004 | 01:19 PM
isaaktnt's Avatar
isaaktnt
Default Something is killing my ears
After $7500 worth of work, my stereo still have some problems. I need expert help to identify the culprit.
Pioneer AVH-P7500
AVIC-80DVD GPS
Kicker Resolution 6.5 components in front with tit tweeter
Kicker Resolution 6.5 combo in rear
A/D/S 5 channel amp
Custom Box with 2- Kicker 8 CompVR
Bass is great tight powerful
Midbass is great tight
Midrange/high is terrible like needle stabbing me in the ear, coming mostly from the tweeters. Try covering it with a napkin or direct it away and its livable. It so bad that I can't leave the EQ on flat cuz it feels like my ears going to bleed. I adjust the eq to make it bearable but now everything sounds muffled and occasionally a squeak or two will come out and eek.
Highs are okay, clear, a little exaggerated but fine
My installer suggest I get another set of speakers for the from with silk dome instead of the titainium. If that is the case I was thinking of swapping out just the tweeters in front for silk ones.
I am just so tired of throw more money into setup, but I really want to fix it.
Please help! Which is it the amp, speakers, tweeters? Thanks
Old Jun 18, 2004 | 02:34 PM
neur0sis's Avatar
neur0sis
man, after $7500 that stereo system should be makin' you a sandwich, and doing your taxes!
I'd lean toward the components you picked. I never really liked Kicker component sets. Way too tinny and harsh.
Something a little higher end, with a silk domed tweeter might help... or if there is an attenuation setting on the component crossover (a lot come with a 0dB and a -3dB setting), try setting it lower.
Old Jun 18, 2004 | 03:10 PM
BENJ-AMG's Avatar
BENJ-AMG
I don't like titanium tweets. Too harsh IMO. A silk dome tweeter will sound more natural and cause you less fatigue. Also, if possible, I would reduce the amount of power you are running to them. If you can reduce the volume by 6 or 9db, you will still hear the highs, believe me.
High frequencies have a tendency to "appear" in a relatively concentrated audio field and placement can drastically reduce the amount of presence that they have. Might wanna try that too.
Old Jun 18, 2004 | 08:49 PM
Beer Goggles's Avatar
Beer Goggles
Turn the X-overs down or take some of the mid-highend out. I had to do that with my Type-Rs. It takes some EQ work but you should be able to get it down.
Old Jun 19, 2004 | 06:32 AM
rplink's Avatar
rplink
In some cases, no amount of eq work will help harsh highs without destroying the soundstage.
You've got an A/D/S amp, so I would guess your installer sells A/D/S speakers as well. Get a demo on a set of 346is. Smooth highs and great midbass.
For what you have invested, I'd ask the installer to demo them in your car.
Good luck.
Jambo016
Sep 16, 2016 01:08 PM
PureR3d
Sep 10, 2015 06:23 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
J Ritt
Sep 2, 2002 09:51 AM
