Need advice on Kenwood Excelon DDX7015, those of you who have it how do you like it?
Old Jul 8, 2004 | 09:15 PM
  #61
kosta157's Avatar
kosta157
that wire harness will also work for the bose set-up, i put mine in about a week ago and got a music keg as well, sounds better with the kenwood then it did with stock and as for playing mp3 off of dvd discs it will not it only says disc error, it will read burnt dvd's though.
Old Jul 8, 2004 | 11:11 PM
  #62
dkny_boi's Avatar
dkny_boi
Nice... that's exactly what i needed to know. I plan on getting a music keg as well... just the smaller capacity one. Which one do you have and how do you like it?
Old Jul 9, 2004 | 02:47 AM
  #63
ACP's Avatar
ACP
Originally posted by FLdrifter
ACP,
great shots. More pictures please. How well does the trim ring fit?
Fits good on the radio, but on in the dash
I sand it down till it would fit
But the trim is flat, and the dash is curved, so it doesn't fit righ, plus it is't wide enough (gap)
I am going to get the Metra kit today, and see if I can shape that to fit, or use both
dkny_boi
The Metra 80-7550 Kit is for Nissan 95-Up, so yes, will fit your z
Old Jul 9, 2004 | 02:48 AM
  #64
ACP's Avatar
ACP
Did you try Both dvd-r and dvd+r ?
Old Jul 9, 2004 | 03:14 AM
  #65
Bahraini350Z's Avatar
Bahraini350Z
Sorry, got in late!! But does it fit in the indash nav space!! And will the nav door be there or does need removing??
Old Jul 9, 2004 | 07:14 AM
  #66
kosta157's Avatar
kosta157
i got the 10gig HD i find it more then enough for me.
I used a dvd+R but i am almost 100% sure it can't read any mp3 off of dvd discs i don't think any monitor combo can read it either with the exception of the kvt915dvd
Old Jul 9, 2004 | 08:17 AM
  #67
Phatmitzu's Avatar
Phatmitzu
Originally posted by ACP
The harness on the right, is the Metra 80-7550 Nissan 95-Up
Got it on eBay from a seller named das181 for $9.99 shipped
The harness on the left is the Kenwood MET KN1680 or KN16-80
It plugs right in the the back of the Kenwood (got the HU today)
and the other end plugs into the Nissan 80-7550
And that plugs right into the z's wiring harness.
Only wiring looks to be that fuse, and ground
Alright, I'll look into it. Thanks
Dude, you did such a nicer job drilling those holes...mine was re-drilled...then re-drilled...then re-drilled
LOL, and I totally dig that factory face plate cover idea. Very clever. Very cool.
Old Jul 9, 2004 | 12:07 PM
  #68
FLdrifter's Avatar
FLdrifter
Default please keep us updated
dkny_boi
please keep us updated.
How big is the gap? Did you take a photo?
THANKS !!!
Old Jul 12, 2004 | 10:29 AM
  #69
ACP's Avatar
ACP
Default Re: please keep us updated
THANKS !!!
Sure, here is some photos
I ended up just using the metra kit..
Old Jul 12, 2004 | 11:32 AM
  #70
HaNkYs_Z's Avatar
HaNkYs_Z
ACP, where can I get the metra kit and how much? thanks
  #71
toykilla's Avatar
toykilla
I got the Nissan wiring harness, and the Kenwood harness, so it should be a pretty easy install.
toykilla, I noticed in your install (thanks for the step by step btw) you have another harness here
Looks like with a fuse.
That is what Comes with the hu correct ?
And you just used the harness for power, didn't run it to the battery ?
Thanks
Below is the Nissan and Kenwood harnesses
I just hardwired the harnesses together and ran all the power and ground to one location. There are two plugs for the radio. The metra doesn not come with the second plug and u will be doing hardwiring anyways.
For those interested my Step-by-step tutorial on the installation is here:
Head Unit Install
For confirmation: YES you can burn mps's onto DVD-R and it works fine (4.7gigs!!). I have mine sorted into folders. My only complaint is the shuffle feature does not work between folders and will only shuffle within a folder.
I am using Ritek Ridata 4.7gb DVD-R discs. You can buy these 50/25$ on newegg.com. I use a Pioneer-107 burner and burn these at 8x with no problem.
Old Jul 12, 2004 | 11:40 AM
  #72
dkny_boi's Avatar
dkny_boi
ACP... that metra kit actually looks pretty good. I'd be happy with that fit personally. You didn't have to modify it all correct? Coz i noticed it has that nice curve in the middle to match the curved part of the dash
Also, thanks toykilla for posting that step-by-step... it's very informative
Old Jul 12, 2004 | 11:49 AM
  #73
toykilla's Avatar
toykilla
you are welcome
Old Jul 12, 2004 | 12:58 PM
  #74
mudger's Avatar
mudger
Thanks
O SWEET, the only thing i was dreading about the install was having to solder and tape every WIRE! THAT IS PLUG AND PLAY I assume it comes with the kenwood and just plugs into your stock nissan harness? ToyKillA: u mention that u will have to hardwire n e ways. R u speaking about the power and ground? if so where would i wire those too if i were to use the METRA kit. SORRY for the questions just dont want to screw up my baby
Old Jul 12, 2004 | 03:21 PM
  #75
ACP's Avatar
ACP
I got my from a local stereo shop
It comes with 2 trim plates
1 is for a single din, and the lower part has a compartment
the other is 2 single dins with a small piece in the middle
I just used that one, and cut the piece off
I let them keep the rest, so they just charged me $5
But you can buy the Metra kit on eBay, or local shop
mudger
If you go back one page, you will see the 2 wiring harness to get
If you buy these, there is no soldering needed, and just 1 wire to cut (black wire / ground on the Nissan metra wiring harness)
You just need to run power, and ground (as the stock z wiring harness doesn't have a ground)
The fuse in toykilla picture, is the Accessory Kenwood wiring harness #2, that comes with the Kenwood
Yellow I ran to the battery (with another fuse)
The Green is the parking wire
And the black is ground
I wired the Green, Black, and Black from the Nissan Metra harness togeter in 1 end of a but connector, and the other end to ground.
I grounded it to the ground used by the stock gauges.
Old Jul 12, 2004 | 06:12 PM
  #76
mudger's Avatar
mudger
OUI sounds confusing. Maybe i will just let a shop do it for me. Anyone know n e good shops around Riverside/LA?
Old Jul 12, 2004 | 06:56 PM
  #77
FLdrifter's Avatar
FLdrifter
ACP ! Looks terrific ! Thanks for all the photos! The metra kit looks good.
..........ps what in the world is up with your triple guagle cluster? WTF? And what is in your nav slot?
Toykilla, thanks again for your input!
Old Jul 13, 2004 | 03:48 AM
  #78
FLdrifter's Avatar
FLdrifter
Cool, what software are you using to create the DVD-R's ??
Thanks!
Old Jul 13, 2004 | 03:52 AM
  #79
FLdrifter's Avatar
FLdrifter
Default Re: Re: please keep us updated
Thanks again!
Really looks good............
.........How does it sound?
What are your impressions?
Old Jul 13, 2004 | 06:13 AM
  #80
toykilla's Avatar
toykilla
I use the latest version of Nero to create DVD's
