Need advice on Kenwood Excelon DDX7015, those of you who have it how do you like it?
Old Jun 24, 2004 | 08:58 AM
FLdrifter's Avatar
FLdrifter
Default Need advice on Kenwood Excelon DDX7015, those of you who have it how do you like it?
I am thinking of buying the Kenwood Excelon DDX7015
Would appreciate input from those of you who have it.
Thanks!
FL Drifter
Old Jun 24, 2004 | 10:45 AM
Phatmitzu's Avatar
Phatmitzu
Love it. Works great. Muti functions and abilities. Touch Screen is nice with fingerprint less surface. Size/tilt angles are perfect for the factory headunit location. Plays BURNED CDs, DVDs, and VCDs.
Only downsides are that 1) you have to find a trim that fits, or DIY one. The one it comes with doesnt fit that well. 2) It does not show the clock unless you switch to the main manual. 3) it gets hella hot when playing for awhile. 4) Not retractable(safety reason).
All and all, I love mine.
Old Jun 24, 2004 | 06:50 PM
FLdrifter's Avatar
FLdrifter
Thanks!
What did you do about the trim ring?
Old Jun 24, 2004 | 07:49 PM
skitzo's Avatar
skitzo
Originally posted by FLdrifter
Thanks!
Its awesome, I love it and it looks great in the dash. Use a metra kit for the trim.
Old Jun 25, 2004 | 02:09 AM
FLdrifter's Avatar
FLdrifter
Wow, that looks sweet!
I have an 04.5 track with Nav. My nav door is motorized, so I need figure out how to work around that. Any chance you have a motorized door too?
Thanks for the pictures, the install looks super.
Where can I get the metra kit?? Do you have a URL for me?
Thanks,
FL drifter
Old Jun 25, 2004 | 06:00 AM
Phatmitzu's Avatar
Phatmitzu
Looks good. I custom cut a carbon fiber plate attached to the trim it came with. Then modified the brackets so the headunit sits flush with the dash.
BEFORE
AFTER
Old Jun 25, 2004 | 11:39 AM
skitzo's Avatar
skitzo
Thanks,
FL drifter
yes that is a 04 touring with nav (motorized door).. Do a search for metra kit on this site i'm sure you'll turn up a link.
Old Jun 25, 2004 | 12:10 PM
FLdrifter's Avatar
FLdrifter
Awesome!
So how do I get the nav door to stay open when I take out the key? It closes when I power off the car.
Old Jun 25, 2004 | 12:13 PM
FLdrifter's Avatar
FLdrifter
Looks great!
Modify brackets? doesnt the head unit screw into the factory brackets? So what did you do, drill new holes in factory bracket??
Thanks,
FL drifter
Old Jun 25, 2004 | 07:19 PM
Phatmitzu's Avatar
Phatmitzu
Looks great!
Thanks,
FL drifter
Yes.
Old Jun 26, 2004 | 04:34 AM
FLdrifter's Avatar
FLdrifter
Great,
I am getting really excited about this head unit !
I read something about a lead that has to be attached to the parking break light. I dont have a service manual and dont have any idea what I need to do for that. This is about the last part of installation i think I will need to figure out.
Thanks,
FL Drifter
Old Jun 26, 2004 | 06:23 AM
toykilla's Avatar
toykilla
Old Jun 26, 2004 | 07:03 AM
FLdrifter's Avatar
FLdrifter
Default nice install
Originally posted by toykilla
[[/B]
WOW toykilla,
that looks sweet! I will definitly be getting the Kenwook head unit.
Can you give me your $0.02 on installation?
Where do I find the parking break wire so that the DVD's will play? Any easy way to bypass this step?
Thanks.
Great shots!
ps what is the image showing on the screen?
Old Jun 26, 2004 | 08:29 AM
skitzo's Avatar
skitzo
Default Re: nice install
WOW toykilla,
Thanks.
Great shots!
Just pop off the shifter console and there will be a green wire running to the ebrake. Just cut and ground this wire and you can watch DVDs anytime you want
Theres no need to keep the nav door open with the car off to use the headunit.
Old Jun 26, 2004 | 09:18 AM
FLdrifter's Avatar
FLdrifter
Default ?
re green wire: Im a little confused. I obviously need to take a look, but want to be sure before I order the hardware. Isnt there some wire that has to run from head unit to ebrake? Is that the green wire you are reffering to? I would appriciate some more detialed info. If the green wire is a "stock" wire, wont the ebrake indicator stay lit on the dash? Please explain.
Re nav door: my nav door is motorizid. It closes automatically when I take out the key. I need it open to get to screws under controls for nav to take off dash. However I dont want to screw up anything by taking apart the dash while the car is "on".
Thanks!!!
Old Jun 26, 2004 | 09:23 AM
blackmumba's Avatar
blackmumba
i have had it and i love it im going to fiberglass my dash so it will sit flush but other that that with the metra kit it works great.
Old Jun 28, 2004 | 06:57 PM
hurahn's Avatar
hurahn
I just got my car back today and I like it. I'm not too worried about it not being flush. I also noticed that it gets hot. That surprised me. Unfortunately mine doesn't work now. I went out to personalize my settings and it just turns off. It's still getting power and you can go through the menus but as soon as you try sirius, a cd or music keg it'll turn off. The little triangle still flashes when it cuts off also. They put the amp(JL Audio e6450) where the bose sub used to be. I hear a fan come on but then it turns off at the same time with the Kenwood so I believe the amp or the fan is the culprit. Wish me luck cuz that bose really sucked and I'm still breaking the car in so I can't REALLY hear the beautiful engine music.
Old Jun 29, 2004 | 03:17 AM
ACP's Avatar
ACP
LookThen modified the brackets so the headunit sits flush with the dash.
Hey Mark, did you or a shop customize the braket ?
If it was you, could you go into more detail on which braket, and what you did to it, to make it fit flush ?
Old Jun 29, 2004 | 03:21 AM
ACP's Avatar
ACP
Those with the metra kit, did you use the double din plate with nothing in the center , or take the one with the divider in the middle, and cut it out ?
I was looking at the metra kit yesterday, and it had 2 trim pieces, and the edges look different, it looks by the pictures, that you guys are using the one with the divider, and cutting it out
Appreciate the help, looking to buy this unit and install it myself
Taken the dash out to installl my gauges, that is pretty straight forward, so I think I can do the sterero.
Oh, and is there a wiring adaptor kit I need to get for the z ?
Thanks!
Old Jun 29, 2004 | 04:57 AM
blackmumba's Avatar
blackmumba
yes cut out the divider and use that one and yes there is a wire adaptor its the metra one for 95 and up nissans
