Burnt Navigation DVD Stuck???
Old Oct 27, 2004 | 09:47 PM
Shahrum's Avatar
Shahrum
Default Burnt Navigation DVD Stuck???
Ok... I just got my car used with navigation and was missing the DVD so I burnt a copy using a dual layer DVD+R (8.5GB) of a nav CD out of an 03 Altima and now that I've inserted it into my DVD drive, not only is it still asking for a map DVD but now it won't let me eject it!!!
Anyone have any idea what I have to do???
Old Oct 28, 2004 | 05:23 AM
Shahrum's Avatar
Shahrum
::bump:: Any ideas on how to get that disk out??
buletman's Avatar
buletman
Only reason I can think of:
DVD+R
I told you in your other post, you should have used DVD-R. +R is not very compatible with most things.
Chad
Old Oct 28, 2004 | 05:45 AM
Shahrum's Avatar
Shahrum
Right but they do not make DVD-R dual layer disks that I could find...
Old Oct 28, 2004 | 06:12 AM
buletman's Avatar
buletman
Ouch, sorry then...
Old Oct 28, 2004 | 08:00 AM
Shahrum's Avatar
Shahrum
That's ok... I took it over to a Nissan dealership this morning... let's see what they can do!! :-\
Old Oct 28, 2004 | 12:23 PM
Shahrum's Avatar
Shahrum
Just picked up my car... Now this is weird...
Turns out the original nav disk was in there all along, and for some reason it wasn't "programmed" so that's why it kept asking for the map DVD. The strange part was... how come I couldn't eject it if it was in there (alone) originally??
And then when I added the DVD+R disk in, it jammed the ejector completely because the slot now had two disks in it at once. So for $45, the Nissan dealership removed the burnt copy and programmed the original Nissan DVD that was apparently in there all along, and it's working perfect!! Yay!! I'm happy now!
Old Oct 29, 2004 | 01:12 PM
BrImSt0ne's Avatar
BrImSt0ne
memorex, fuji, sony. just about all the dvd-r's on the market will burn dual layer.
Old Oct 30, 2004 | 02:46 PM
Slip and Slide's Avatar
Slip and Slide
Anyone want to burn me a updated Navigation disk for some $$$...
Old Oct 30, 2004 | 04:46 PM
Shift_Daytona Z's Avatar
Shift_Daytona Z
yes I would also like one
Old Nov 2, 2004 | 08:19 AM
mdracer76's Avatar
mdracer76
I'd Buy too!
Old Nov 2, 2004 | 08:52 AM
barrybell's Avatar
barrybell
DVD-9, which is a DVD-R are only available to the DVD movie industry at the moment. Early 2005 the PC burners will be released at a street cost of $300, the discs will be $10 ea. until the market catches up.
Old Nov 2, 2004 | 10:07 PM
sundawg's Avatar
sundawg
where is the cheapest place to buy an updated nav disk and when do the new ones usually come out ie. end of the year or at the beginging. i have an 03Z and it has the 6.0 disk in it, leme knoe thanx
sunny
Old Nov 3, 2004 | 02:53 PM
Slip and Slide
I second that If they are coming out with a updated Nav disk for 05' in January then sign me up. Anyone know anywhere cheap to buy them?
Old Nov 4, 2004 | 05:47 AM
roydiculous's Avatar
roydiculous
I was going to say - it doesn't matter the format of the DVD/CD - your ejector mechanism is messed up.
If I put a computer CD in my car's stereo, it wouldn't get stuck, it just wouldn't play!
Glad they fixed it for $45 - seems reasonable. Did they question you about the burned NAV DVD?
Old Nov 4, 2004 | 06:46 AM
butterwm's Avatar
butterwm
Does anyone know how much the updated Nav DVD's cost at the dealership and how often they come out?
Old Nov 7, 2004 | 05:57 AM
Blade Extremeskins's Avatar
Blade Extremeskins
Shahrum,
Have you tried to use your burnt NAV DVD now that your player is working correctly?
If so, (and it works) what software did you use to burn the DVD?
-Thanks
Old Nov 8, 2004 | 01:19 AM
XBS's Avatar
XBS
Veteran
i also need to get an updated DVD for my nav what is the newest version and were can i get it ill burn some copys
Old Nov 8, 2004 | 12:47 PM
Slip and Slide
I know you can buy them at zenrin.com however they are $185. If anyone has a DVD for any other 05' Nissan with Navigation I'm sure they could help a lot of people out and make a couple bucks. There has to be someone out there...
jlb
Oct 15, 2017 05:10 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Beater350z
Sep 9, 2015 03:36 PM
