Help - Speaker wire routing
Old Nov 9, 2004 | 05:17 AM
mcoupe79's Avatar
mcoupe79
Default Help - Speaker wire routing
I'm in the process of following the How-To on this site for routing speaker wire through the existing door connector. I've routed the wire, and am putting the connector back together. I've got everything back together, but have a problem. When the door is open, everything works properly (windows, mirror, lock). However, as soon as I slam the door shut, everything stops working. As soon as I open the door again, though, everything works again. I've actually found that if I shut the door very lightly, everything still works, but obviously this is not a long term fix. Can anyone help me with ideas?? Thanks!
Old Nov 9, 2004 | 05:36 AM
King Tut's Avatar
King Tut
Hmm, I would say that you might have drilled out the connector improperly and some of the metal pins might be getting squished and are making contact with each other when you close the door.
Old Nov 9, 2004 | 06:22 AM
dannichols's Avatar
dannichols
I did the same mod. Take the connector back apart and ensure you didn't drill through any other connectors. Strange thing with mine...I did the mod about 3 months ago and everything has worked, but with a new head unit now if I slam the door shut, the stereo goes mute for about 3 seconds..and then starts working again??
What size wire did you use
Old Nov 9, 2004 | 06:40 AM
mcoupe79's Avatar
mcoupe79
I'll have to check on the drilling tonight. If that is the case, what are my options for a fix? Do I need to replace the entire connector?
I'm running 2 26 gauge wires through (diamond audio crossovers wouldn't fit on the doors).
Thanks for everyone's help.
Old Nov 9, 2004 | 06:48 AM
mcoupe79's Avatar
mcoupe79
Also, if I'm shorting some wires together, wouldn't that mean that some of the connections would still work? In my case, neither the window or the power mirror work when the door is slammed. Just a thought...
Old Nov 9, 2004 | 09:33 AM
motown's Avatar
motown
26 gauge? Man, first you need better wire. That's strangling your poor speakers. Second, I really hope you haven't mangled that molex. I can't imagine it's cheap for the dealer to fix that. I'd take apart the plug and make sure all of the pins are still in place and properly aligned. Maybe post some pix if you can. Would be helpful to see what the problem could be. Whatever it ends up being, I hope for you it's not serious.....
Old Nov 9, 2004 | 09:41 AM
dannichols's Avatar
dannichols
The stock wiring is thicker that 26 gauge isn't it? Are you sure the stuff you ran isn't 18 or 20?
It's very odd that everything stops working. I remember running the wires through that Molex piece, it was a PITA. The two sides of the connector came together by pulling up on a clasp until it locked. Are you sure that connector locked all the way shut so there is proper electrical connectivity between both sides? Also, the wire you ran had to be pulled taught so that it didn't create a kink in between the connector.
One more question, does the speaker work when you slam the door? If it does I would guess the connector is not seated properly.
Old Nov 9, 2004 | 09:47 AM
mcoupe79's Avatar
mcoupe79
Hah... sorry everyone. Typo. I meant 16 gauge.
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
