Audio Builds Audio projects and builds from my350z members
Farenheit Installation
Old Aug 9, 2005 | 12:00 PM
AZ350Z's Avatar
AZ350Z
Did you have to take the Farenheit out of it's shell to fit it in the cubby? I have my car at the installer now and they cant figure it out...
Old Aug 9, 2005 | 02:40 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by jdg345
What camera are you planning on using and what are your thoughts on mounting? I was thinking about doing the same (though I wanted front and back cameras).
I've got the standard e-bay rear view $37.95 camera on order. It was the smallest I could find and I'll mount the back-up camera just above the license frame. Being a SB the black of the camera will blend right in. If I didn't have an SB color car I would have bought one of the $200 license plate frames with the camera mounted in the top of them.
For the forward facing camera I thought it would be nice to have it mounted in the license plate itself so I'll pop a 1/8" hole and mount a pin hole camera in there. Figure something color with +380 lines of resolution and a 2.8-3.6 mm wide angle lens. I'll pick it out of supercircuits.com when the time comes. I've got five or six of their cameras around the house to play with which lens would look best that low. I don't like having to wear the front plate and I'm forever pulling it on and putting it back ... the camera will slow me down a bit and help keep me legal.
Old Aug 9, 2005 | 02:42 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You need to fire your installer!
Do you have the '03 cubby or are they trying to get it into the '04.5-'05 one that uses a different door?
Old Aug 9, 2005 | 03:12 PM
jdg345's Avatar
jdg345
So are you sposed to pull it out of the shell or no?
Old Aug 9, 2005 | 04:12 PM
AZ350Z's Avatar
AZ350Z
I have the 03. Just left the installer, without getting the screen installed...now I gotta try it myself....
Old Aug 9, 2005 | 04:33 PM
AZ350Z's Avatar
AZ350Z
My big questions are: How do I remove the cubby itself, and once I get the screen hooked into the cubby, how do I connect it to the x-box cables and power?
Old Aug 12, 2005 | 09:11 AM
Austin350ZRed's Avatar
Austin350ZRed
All of your questions regarding how to remove the cubby, how to install the screen, how to connect cables are answered elsewhere on this forum already. The only reason I'm chiming in is because I've spent the last few days researching the same questions.
'03 350Z (Girlfriend's)
No Modifications
Old Aug 12, 2005 | 05:55 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
No.
Here's picture proof:
Old Aug 12, 2005 | 06:12 PM
jdg345's Avatar
jdg345
Paul,
I think you're my new hero ...
When I get the courage to try to take apart my center console I'll be referring back to some of these threads. Right now, I can't even get my V1 hardwired -- and that is supposed to be easy.
Old Oct 21, 2005 | 01:27 PM
spinez's Avatar
spinez
I just got done with installing this lcd into '03 cubby on my '04 enthusiast. All in all it was pretty dang easy.
My question is this.. it seems the cubby is a slightly different color than the stock cubby and doesnt quite match the rest of the console. Is this the same experience others have? Any way to remedy it?
Also is there a way to make the lcd turn on automatically when the car is started? I wired it to switched power on my head unit. Would wiring it to constant power make it turn on automatically?
Old Oct 21, 2005 | 02:30 PM
HockeyZ39's Avatar
HockeyZ39
Dumb question but how do you supply power to the LCD? doesnt it come with a normal wall jack?
Sorry if its a dumb question!
Old Oct 21, 2005 | 03:32 PM
spinez's Avatar
spinez
its got a red and black wire for power and ground.. hook it up to your headunit wires or anything else you can think of that has power and ground
Old Oct 21, 2005 | 09:52 PM
HockeyZ39's Avatar
HockeyZ39
Well that works out good then!
Old Feb 9, 2006 | 06:29 PM
shizzawha's Avatar
shizzawha
Alright I've got an 04 touring roadster. Is the 03 lid from performance nissan going to be a different color like spinez was saying or does it match up? Also I noticed that this thread was a little old, can you still get the farenheit screen at the website posted? I can't seem to find it. Any help is appreciated.
Old Feb 9, 2006 | 06:41 PM
dark_muppet's Avatar
dark_muppet
I've got a couple if you want to buy one. They're not in the box anymore but they've never been installed.
Old Feb 9, 2006 | 06:48 PM
jdg345's Avatar
jdg345
millionbuy has the screens ... but they definitely don't match up with the 2005's ... it's not too too bad ... and I figure I'll get an overlay kit anyways ...
Old Feb 9, 2006 | 08:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The color is a bit off but it looks fine - nobody has really noticed it or said a thing if they did. Looks like it was designed that way even.
Old Feb 9, 2006 | 08:40 PM
  #38
jdg345's Avatar
jdg345
I dunno ... I can tell on mine ... maybe cause I always have the top down with the roadster ... the top curve is also a little different ... I can mostly tell cause I know where to look I guess ... most folks don't pay that much attention.
I'm not even very handy but thanks to you this is something I was able to do myself!
Old Feb 10, 2006 | 08:15 PM
  #39
shizzawha's Avatar
shizzawha
Anyone have any pictures of the 03 lid in an 04? I'd like to see what you guys are talking about. Also, dark muppet how much you want for the monitor and are they in perfect condition?
Old Feb 10, 2006 | 10:17 PM
  #40
usmanasif's Avatar
usmanasif
Good job, Paul! Very neat install.
