Audio Builds Audio projects and builds from my350z members
Farenheit Installation
Old Mar 26, 2006 | 01:50 PM
  #61
StifflerHB's Avatar
StifflerHB
Look at the Power Acoustik PT-700MHR Monitor from millionbuy.com. Its the same like the Farenheit. Fits perfect !
My install
Attached Thumbnails Farenheit Installation-dvd-1.jpg   Farenheit Installation-dsc00036.jpg
Old Mar 26, 2006 | 06:00 PM
  #62
Mike Wazowski's Avatar
Mike Wazowski
My install
Power Acoustik makes the Farenheit it is the exact same screen different name.
Old Mar 30, 2006 | 04:00 PM
  #63
loquitoy2k's Avatar
loquitoy2k
Originally Posted by lurch
I have a question, does the 2003 lid cluster fit on the 2006 models. the only reason i'm asking is because there is no bracket for the 2006 model for regular head units so I am thinking the the lid cluster is slightly different as well.
+1 ??????
Old Mar 30, 2006 | 06:37 PM
  #64
maxipad96's Avatar
maxipad96
Only one way to find out. Be the test mule. I'll tell you what, if it doesn't fit, I'll buy it from you for what you pay through performance nissan. I need a new 03 one actually.
Old Mar 30, 2006 | 07:28 PM
  #65
loquitoy2k's Avatar
loquitoy2k
I will probably be doing in it in a couple weeks. That's a great idea!
Old Mar 31, 2006 | 11:47 AM
  #66
sorphin's Avatar
sorphin
ok.. someone's got FARENHEIT T-7000MHR 7"'s on eeee-bay, those the ones you guys are using? i've thought about getting a screen for a couple cameras for my roadster (which is an 06 btw, so i may be a guineapig)..
Old Mar 31, 2006 | 11:59 AM
  #67
Ed 718's Avatar
Ed 718
BRAVEHEART
Paul posted what LCD he used on the FIRST page of this thread....
Old Mar 31, 2006 | 12:39 PM
  #68
sorphin's Avatar
sorphin
sorry.. work's killing me.. ignore my post then.
Old Mar 31, 2006 | 07:12 PM
  #69
jdg345's Avatar
jdg345
And as mentioned, the Power Acoustik PT-700MHR is the same unit as well ... available from millionbuy.com
Old Mar 31, 2006 | 08:23 PM
  #70
Paul350Z's Avatar
Paul350Z
Living in 350Z
That's who I got my Farenheit from last year - $137 IIRC.
Old Mar 31, 2006 | 10:15 PM
  #71
sorphin's Avatar
sorphin
I just compared the Farenheit and the Power Acoustik.. the Power Acoustik (according to the specs) has a higher resolution.. it's 2400x480 vs the Farenheit which says 1440x234.. anyone know how accurate that is?
Old Apr 1, 2006 | 05:16 AM
  #72
jdg345's Avatar
jdg345
I bought my Fahrenheit from them too ... back in October/November I think ... but it was a little less I thought?
btw: what's IIRC?
Old Apr 1, 2006 | 05:29 AM
  #73
Mike Wazowski
btw: what's IIRC?
If I Remember Correctly
Old Apr 1, 2006 | 05:58 AM
  #74
jdg345's Avatar
jdg345
Oh yah ... duh!
Old Apr 2, 2006 | 03:37 PM
  #75
HockeyZ39's Avatar
HockeyZ39
Quick question, my DVD head units (JVC KD-DV5100) has a wire that is "suppost" to be attached to the parking brake so it does not play with out the parking brake up. What should I attach it to so it can run while the parking brake isnt up? I tried the 12v to the ignition, and still got the "brake needs to be up" thing.
Also it is all fuzzy and split into 3 sections, like on an older tv that is cycling up. My head unit has a female end and the T-7000 has a female end so I just used a normal RCA video cable to connect them. Is this correct? TIA for the help!
Old Apr 2, 2006 | 04:10 PM
  #76
Mike Wazowski
try connecting the wire to a solid ground and see if it will fool the HU into lettig you watch movies while the car is moving. If not, yes it neds to go to your parking brake.
Yes you only need regualt RCA cables to do the connection.
Good luck post pics when you get everything up and working.
Old Apr 2, 2006 | 04:37 PM
  #77
Ahsmo's Avatar
Ahsmo
Imakecopies
+1 ^^^
just ground that b!tch
Old Apr 2, 2006 | 04:43 PM
  #78
HockeyZ39's Avatar
HockeyZ39
Gounded it, not getting the "put brake up" msg any more.
But the screen is flickering like and old tv where the picture keeps going up!(but it is split into 3 screens and is going up.) I have the red wire connected to the 12v accessory wire, and the black connected to a ground and connected with just a normal RCA wire. Thanks for the help so far guys!
Should I connect the screen to the wire that goes to the battery not the accesory wire?
Old Apr 2, 2006 | 05:42 PM
  #79
HockeyZ39's Avatar
HockeyZ39
Never mind just had to change one of the settings on the LCD. Thanks again for the help guys.
I would post up some pictures but it looks just the same as all the others!
Old Apr 2, 2006 | 06:43 PM
  #80
sorphin's Avatar
sorphin
any answers about the resolution question?
