Audio Builds Audio projects and builds from my350z members
Farenheit Installation
Old Jun 19, 2006 | 07:49 AM
  #101
HockeyZ39's Avatar
HockeyZ39
Two inputs would be nice but my head units has 2 aux ports so I guess I dont really need a second.
Old Jun 19, 2006 | 08:40 AM
  #102
Kaitain's Avatar
Kaitain
My head unit (AVIC-Z1) has multiple video inputs and outputs too but this screen will be used with both the head unit and the CarPC so having two inputs allows me to switch back and forth easily. I want to have the head unit hooked up to that monitor so that on long trips I can have the Nav going constantly on the HU while my girlfriend can keep watching her DVDs on the LCD.
Old Jun 19, 2006 | 08:50 AM
  #103
HockeyZ39's Avatar
HockeyZ39
But couldnt you put the PC into one of the headunit inputs? All you have to do is hid the source button to switch between the two? And the 7001 doesnt have vga so your going to have to convert either way.
Old Jun 19, 2006 | 06:06 PM
  #104
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by sorphin
i could still use an answer to my resolution question
Sorry I didn't see this thead ... I was off to Atlanta and didn't spend much time surfing.
In my highly trained and proffessional opinion the Farenheit has a better picture.
I used an Avia Home Theater DVD to set both audio and video levels of my system. The Farenhiet display has more controls than the Pioneer for picture adjustments and I was able to set brightness, contrast, hue, and saturation to the perfectly correct levels using the test patterns on the disk. I found the brightness of the Farenheit to be set way too high with a factory setting of 100 where careful adjustment found the proper setting to be 61. Both are pretty high resolution but the Farenhiet runs all the way upto the resolution limit of standard definition NTSC where the Pioneer came out just a tad shorter but not enough to notice with anything other than a resolution chart.
The Farenhiet screen is also a tad bigger - that 0.5" makes a difference when you're talking 6.5" vs. 7" ...
Old Jun 19, 2006 | 06:09 PM
  #105
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by Kaitain
Any reason you used the T-7000MHR instead of the T-7001MHR? The only difference I can tell is the 7001 is the newer model that has 2 inputs vs. 1 but they both seem to be discontinued. I can still find them, but everyone says they are discontinued.
Anyway, I'm wondering if the 7001 is the exact same size as the 7000. I'd rather have two input than one...
I couldn't find a 7001 at the time ... and only needed one video input too. I've kicked around the idea of a second camera facing forwards mounted really low to the road with a wild wide angle ... just for kicks (and avoiding curb scrapes with the chin). If I install one I'll just install a tiny A/B switch some where hidden from view - possibly in the center cubby where my iPod interface and LED lights are hidden now.
Old Jul 19, 2006 | 08:38 PM
  #106
DesiZ_06's Avatar
DesiZ_06
hey ive been doin my hw lately, i want to know if the BOSE HU for my 2006 touring model will need any AUX port such as PAC-NISS2 for the video ipod to the fahrenheit LCD ?
can you tell me how i should go about connecting the video ipod to the fahrenheit lcd so i can see the playlist on the screen that is being displayed on video ipod?
by the way, i want to keep my factory BOSE HU. let me know thanx! i've been wanting to do this and im this close to get it done..i'll be so grateful if i can have this behind me now..thanx!
i want to talk to my installer and see how well he knows about it..he has audio shop..but i want to be safe and have informations
Old Jul 20, 2006 | 06:50 AM
  #107
DesiZ_06's Avatar
DesiZ_06
???????????/ anyone??
Old Jul 20, 2006 | 06:53 AM
  #108
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
hmm if is possible to connect video ipod to the fahrenheit LCD and able to watch video, then it would be alwsome! and i would get it right now!!
Old Jul 20, 2006 | 08:46 AM
  #109
DesiZ_06's Avatar
DesiZ_06
it is possible to do it because the fahrenheit has the s-video wire..so i thought if i can get the pac-niss2 aux port and get the video cable for the video ipod from apple..and wire it all..but i need know...if i need the PAC-NISS2 for the 2006 BOSE HU..since people has been saying to get the PAC-NISS2 aux port for the BOSE HU for the 2003-2005 models...so...im lost!!!
Old Jul 20, 2006 | 05:00 PM
  #110
Paul350Z's Avatar
Paul350Z
Living in 350Z
Well it's been over a year but I don't recall seeing anything but a normal line level RCA cable input - and no S-video input. I would think the video iPod has a normal composite video output which is a normal input to the Farenheit video screen.
Looking at the iPod AV connection kit on Apple's web site:
iPod AV Cable
On one end, the iPod AV Cable connects to the headphone port of the iPod or the line-out port on the iPod Universal Dock. On the other end, it connects to the left/right stereo input jacks on a stereo, powered speakers or TV and the composite video input on a TV or monitor.
S-video is normal a componet output - I'm not thinking s-video is an option here. The Farenheit will work baring anyone proving to me that it doesn't have composite video output.
The iPod AV Cable will connect into video input of the Farenheit. How you get the audio into the stock head end is another matter - I don't need a PAC-NISS2 as my Pioneer AVIC has AV inputs and outputs.
Old Jul 20, 2006 | 05:56 PM
  #111
HockeyZ39's Avatar
HockeyZ39
My HU is ipod ready, there is a jack in the front to hook it up, so I just go from Ipod -> HU -> screen.
Old Jul 21, 2006 | 10:18 AM
  #112
behjjeh's Avatar
behjjeh
can you use navi and play movie at same time?
Old Jul 21, 2006 | 07:58 PM
  #113
DesiZ_06's Avatar
DesiZ_06
whats ur headunit??
Old Jul 22, 2006 | 07:05 AM
  #114
HockeyZ39's Avatar
HockeyZ39
Sorry I couldnt respond to your PM it does not go through at work for some reason. My HU is in my sig below \/\/\/\/\/\/
Do a search on google for it, you can find all the goods on it. If you look at the pics you can see the jack for it on the far right.
Old Jul 22, 2006 | 07:41 AM
  #115
DesiZ_06's Avatar
DesiZ_06
hey can you tell me about ur experiences with your HU...
tel me the pros and cons...
can you see the playlist being displayed on ur fahrenheit screen?? if i got a video ipod, u think it will be able to play videos or music videos on the screen thru that headunit? please reply..thanx!
its ok about the pm...
Old Jul 22, 2006 | 07:50 AM
  #116
HockeyZ39's Avatar
HockeyZ39
I have only hooked up a normal Ipod not a video, and yes it shows a heads up display on your screen. Same when you have burned CD's it shows on the heads up. The real neat thing is this head unit show meta tag info on the screen. So if gives artist name, cd title, rating, genre, and so on and so forth. It also supports many folders on the cd/dvd. So I have all my music broken up into genre folders so I can quickly jump into which ever music I want to listen to, and then just set it on random play. One last cood feature is it reads burned dvd's so you can put 4.3 gig's of songs (or music videos) on a dvd, set it up in folders for easy browsing and it makes for a real nice set up. Do some looking around on the net or send a msg to JVD tech support to see if the front aux will play video. I love the HU and am very happy with it, and the price is pretty good to (I picked mine up for 190) There are also more video in's in the back if the aux in the front does not support video. You could just drill a hole to the side of the head unit (in the dash trim) and mound the video in there, so you could quicly hook up your ipod video.
Old Jul 22, 2006 | 08:03 AM
  #117
DesiZ_06's Avatar
DesiZ_06
sweet! i'll check out the product and contact the tech support!
thanx for the info...my god..this is just the easy solution!! a simple headunit that can play dvd and such....with an ipod hookup...nice..
now i dont have to go thru that pac-niss aux or any other aux crap!
Old Aug 7, 2006 | 02:59 PM
  #118
behjjeh's Avatar
behjjeh
can we fit Farenheit in to 06 dash?
thanks~
Old Aug 17, 2006 | 01:25 PM
  #119
dragone2717's Avatar
dragone2717
I am looking for the smallest Cameras that I can install in front and rear of the car and connet them to my screens. Any suggestions to which one would be good for this projet?
Old Aug 17, 2006 | 01:27 PM
  #120
dragone2717
BTW I've seen the one's that come in the lincense frame and I was not a big fan.. I looking for some thing I can Hide ine the front bumper behind the grill and under niether the hatch for the rear.
Thanx
