Audio Builds Audio projects and builds from my350z members
Finally got the LCD screen installed..
Old Sep 2, 2008 | 03:16 PM
  #61
AUtigers350z's Avatar
AUtigers350z
Thanks all. Preciate the kind words
Originally Posted by spdtckts
great build up.
one question. is that the headrest unit?
The TV screen in the cubby is actually "technically" a headrest unit. The reason you don't have to ground or switch any wires to make it think the e-brake is up is because it thinks its in the back of my headrest
Old Sep 30, 2008 | 12:39 PM
  #62
Son of Mad Dog's Avatar
Son of Mad Dog
So i only have to ask,
how did you run the speaker wire to the door components?
the Rear speakers make sense.
The front dont.
Did you have to rewire to the component from the amp?
^ this is the part i fear most.
Of course i have a base stereo. So if i ever want sub/better sound i have a long way to go.
Old Oct 22, 2008 | 08:54 PM
  #63
AUtigers350z
The front dont.
I ran the speaker wire for the door components thru a black plastic piece on the outside of the door.
See if this helps..
http://liljerk.morpheus.net/350Z/front_speakers/
I ran new wire from all the speakers to my Alpine amplifier. Just taped the Bose down to prevent rattles and in case I ever need them again.
Old Oct 23, 2008 | 04:16 PM
  #64
Voboy's Avatar
Voboy
The front dont.
you should be scared... running new wires through the door is a *****!!!
Here's the DIY thread for it:
https://my350z.com/forum/audio-video...ire-doors.html
Oh yeah, be real careful when drilling that plug... some people lost their window/lock/mirror control :O
Old Nov 6, 2008 | 05:16 AM
  #65
350Zrida's Avatar
350Zrida
You have alpine rears and a polk component set in the front right? How does that sound?
Old Nov 13, 2008 | 06:51 PM
  #66
burner's Avatar
burner
Nice work! I have a very similar setup although I am running a slim PS2 & nav hooked to an A/V switch instead of an Xbox, and the Pioneer double-din. Here is a pic:
Old Nov 14, 2008 | 01:16 PM
  #67
AUtigers350z
Sounds pretty good to me I suppose. I'm not as big of a hardcore sound enthusiast as some people on here, so I wouldn't be able to tell you the difference between the Polks and a nice set of JLs. For what I want though, they work perfectly.
Awesome setup! Looks like a P4000? What Nav are you running on the external screen? I looked at the Garmin GVN-52 a while back when I was considering going that route.
Old Nov 14, 2008 | 02:08 PM
  #68
dkmesa350z's Avatar
dkmesa350z
nice! looks very clean.
Old Nov 14, 2008 | 10:06 PM
  #69
chrisl113's Avatar
chrisl113
so forgive me im new to the concept but very interested in installing this same screen in my 07, but im learning quickly that different years have different fitments.... so my question is what i need to install this screen in my 07 cubby hole? thanks!!
Old Nov 17, 2008 | 10:00 AM
  #70
350Zrida's Avatar
350Zrida
http://www.kenwoodusa.com/Car_Entert...Video/KOS-L702
That should do it. I plan on picking one of these up in the future to finish up my system.
Old Nov 17, 2008 | 11:54 AM
  #71
ADMAN's Avatar
ADMAN
Old Nov 17, 2008 | 12:19 PM
  #72
chrisl113's Avatar
chrisl113
^^^ thanks but im getting the faranheit screen im talking about the plastic hardware pieces, like a certain year cubby that has the door slide in that can be modified to fit a screen but still matches the 07 interior (if there are differences).
ADMAN: what all did you have to by to get that screen in there?
Old Nov 22, 2008 | 08:44 PM
  #73
chrisl113's Avatar
chrisl113
in for an answer?!!?
Old Nov 24, 2008 | 08:29 PM
  #74
chrisl113's Avatar
chrisl113
anyone on these forums anymore?
Old Nov 24, 2008 | 09:39 PM
  #75
AUtigers350z
Sorry man, I don't have an 07 so I didn't have to do any research as to which model would or wouldn't fit. I know the 03 cubby works, but as far as fitment in an 07 or matching the color of the dash I can't be sure.
Old Nov 25, 2008 | 07:15 AM
  #76
chrisl113's Avatar
chrisl113
thanks man, seems like no one has done this? i saw a store the other selling 03 cubbies but said fitment wasnt ok with 06+....
Old Nov 26, 2008 | 03:47 PM
  #77
Spike100's Avatar
Spike100
Mounting a LCD screen in the upper/forward cubby of a ’07 Z is certainly possible and comparatively simple. There is adequate room behind the cubby’s “face.”
It’s a matter of cutting out the back of the cubby and building a mount to hold the screen. This requires some minor custom fabrication, but any high-end shop can do this. It certainly is less complicated that some of the extensive “glassing” projects we’ve seen here to do things like mounting tweeters in the A-Pillar or fabricating SubW enclosures.
--Spike
Old Nov 26, 2008 | 08:49 PM
  #78
chrisl113's Avatar
chrisl113
ok thanks spike, but the 07 cubbies dont have the retractable door... thats why i wanted to know what else i can do to get the retractable door or something?
Old Nov 28, 2008 | 04:14 PM
  #79
Spike100's Avatar
Spike100
^^ I get it now.
Installing a retractable door on an '07 would be difficult and expensive. That would involve a lot of fabrication, and the mechanical aspect would be prone to failure with repeated use. I wouldn't do it.
--Spike
Old Nov 28, 2008 | 08:08 PM
  #80
chrisl113's Avatar
chrisl113
really? wow, is the 03 cubby that different form the 07? thanks!
