Audio Builds Audio projects and builds from my350z members
Very large sub in a G coupe install :) pics
Old 09-07-2007, 04:36 PM
16psibrick
Simplicity in Sound
16psibrick's Avatar
Default Very large sub in a G coupe install :) pics
okay, so this time i got to do sorta the opposite of my normal stealthy installs...and it was perhaps one of the most challenging G installs i have done.
The customer had alrady bought a bunch of gear, whcih after talking to him, i immediately recommended to him to change out the sub. In all fairness to him, he had bought the gear before the G coupe, not knowing he would get a car with small trunk hehe.
but anyway, it tuned out we had to go with the gear already purchase...so...
here is the problem...the sub he has is the Phoenix Gold Titanium Elite 12, hands down one of the biggest 12" subs out there, bigger even in outter dimensions than the jl 12w7!
to give you a better idea of the challengs facing the install...here are the gear thats going in the trunk...note that the sub is 13.5" wide and 11' deep! and also two relatiely large PG amps...
that should already mean something to you Coupe owners lol...but here is the space we have to work with, from the front part of the trunk, floor to ceiling is only about 10.75" tall! that means there is no way to really fit the sub in the normal ways...not to mention if factor into the account that the subbox that it needs, and the subbox's wall thickness...yikes!
well, enough whining lol...lets get onto the install...
goals:
1. Obviously, stealth and space is not hte goal here, but the owner still like to be able to keep a little bit of usable room in the trunk for small items.
2. Having decent SQ while retaining the factory bose system - this proved to be an additional challenge to the trunk becuase the bose amp can not be removed to gain more space...
so...here is the headunit, stock, i located the phoenix gold LPL44 remote bass **** on the center console area for easy access, its down by the shifter:
the front stage is a hybrid, the customer provide a pair of MB Quart Q series midbass, whcih were installed in the factory lower door location, the entire door was of course dampeend and new wire ran into the door. a set of DLS ultimate iridium tweeters were flushed into the stock kick panel. this gives an overall response a bit less harsh than the full Q set
moving on to the main part, the trunk...here is the normal view, with part fo the stock carpet in place, and the cargo net so the customer can still load some small items in the trunk:
remove the carpet and netting and here is what you see, a full vinyl front wall and fake floor, that extends to the edges of the trunk, wtih two grilles covering openings in the middle of both surfaces. the floor part was not raised at all
pop those covers off, and this is what you get. My solution to the large sub issue was to utilize the space BELOW the stock floor for the subbox, and then mount the sub upside down and surround the top side with a suede covered housing for cosmetic effect. the amps are in there own suede lined well towards the back of the trunk. both are topped with clear plexi. The stock bose amp and other modules on the driver side trunk were relocated to clear the amp rack.
to boose the signal going to the amps from the stock headunit measure 1voltish to a full 8-10 volts is a Phoenix gold line driver. the Titanium 500.4 runs the front stage fully active with 75 watts per speaker, and the 800.1 sends over 800 watts to the titainium elite 12
those its kinda hard to see, the front wall is acutlaly part fiberglass, becusae in parts it protrudes PAST the open of the trunk, so i glassed a top "lip" so one wouldnt see behind the wall
and finally to better illustrate how the subbox works, here is the view with the fake floor and front wall removed:
overall, sounds pretty good, very dynamic, a few improvements can be had with a real headunit, but not bad...and i am just glad i found a way to fit that monster
Old 09-07-2007, 05:09 PM
QuicksilverZ33
QuicksilverZ33's Avatar
The work you guys do is just awesome...great work!
Old 09-07-2007, 05:10 PM
16psibrick
Simplicity in Sound
16psibrick's Avatar
thanks, and there is no us guys, its just me
whcih is why this car was a pain, litereally, to my lower back, hauling that beast in and out lol
b
Old 09-07-2007, 07:10 PM
DVFlyer
Speed of White
DVFlyer's Avatar
Sweeeeeeet. So is that box a type of bandpass?
Old 09-07-2007, 07:24 PM
Ruthless18x
Ruthless18x's Avatar
That looks good, I bet it hits hard as hell.
Old 09-07-2007, 07:54 PM
16psibrick
Simplicity in Sound
16psibrick's Avatar
nah, not a bandpass, just a normal sealed box, with a decorative housing around the sub, as you can see, the entire top of the top part is open
it hits poretty hard, though the stock headunit defintely still plays with the bass somehwat, if he had an aftermarket headunit, the bass would be quite a bit louder IMO
b
Old 09-08-2007, 04:29 AM
Lsmith9523
Lsmith9523's Avatar
Man Bing,,,that is really, really nice. You can come and pick up the keys to my Z for an install any day. Let me know, I will leave them at the front door...LOL
I had to go back and look at the photos again. That is AWESOME!
Great Job!!!!!!!
Old 09-08-2007, 04:37 AM
TheBlackPearlZ
TheBlackPearlZ's Avatar
gorgeous...and congrats on getting it in there
Old 09-08-2007, 04:01 PM
skochur
skochur's Avatar
looks good....i like it alott...
Old 09-10-2007, 08:06 AM
kdogg24
kdogg24's Avatar
WOW! NICE!
Old 09-10-2007, 08:09 AM
Bolaz
Bolaz's Avatar
I like it a lot
Old 09-10-2007, 10:30 PM
Vestax
Vestax's Avatar
Bing, you weren't kidding when you said it was huge. Glad you got it in there.
Old 09-13-2007, 08:56 AM
NoahzBurnt
NoahzBurnt's Avatar
Bing- correct me if I am wrong but to counter act the large displacement of that sub did you revese mount it in a sealed box firing up at the deck???
If so.....FREAKEN SCHWEEEET
Old 09-13-2007, 09:56 AM
16psibrick
Simplicity in Sound
16psibrick's Avatar
yeah pretty much, two reasons to do it:
1. as you said, if i need to acount for the HUGE displacement of the sub, the subbox i need will be even bigger
2. its also in the end to me, the best compromise between space savings and cosmetics
b
Old 09-17-2007, 10:18 AM
Nazar
Nazar's Avatar
Nicely done as usual. Sorry to hear about your back.
Old 09-20-2007, 12:25 PM
tonester1011
CF God
tonester1011's Avatar
i likes!!!
Old 09-20-2007, 04:03 PM
VO...
Administrator
VO...'s Avatar
Received 2,747 Likes on 1,836 Posts
That is one sick install! Good job.
Old 09-20-2007, 07:23 PM
Swiffer
Swiffer's Avatar
Awesome job! Ballpark figure for an install like that? (not including gear)
Old 09-20-2007, 08:28 PM
masterj26
masterj26's Avatar
amazing work as always
Old 09-21-2007, 07:05 AM
16psibrick
Simplicity in Sound
16psibrick's Avatar
if i were to do it again, mid 1k range, including everything in terms of labor related...
b
Quick Reply: Very large sub in a G coupe install :) pics
