Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old Jan 24, 2008 | 06:35 AM
  #201
VO...'s Avatar
VO...
Administrator
Originally Posted by 350zspl
always use 1 or the other not both , your ear never lies , if the hu crossover is better to your ear than the amp than go with it
So are you saying to turn the amp's crossover potentiometer to the highest cut-off setting now? It's currently at 55Hz and sounds great to me..
Old Jan 24, 2008 | 06:40 AM
  #202
350zspl's Avatar
350zspl
your amp LP is at 55 on the RF and your HU LP is at 80???? is this right
Old Jan 24, 2008 | 06:42 AM
  #203
clarkemtp's Avatar
clarkemtp
The link Doug posted is where you get it. Once they recieve the paypal payment, you'll recieve the sub in about a week.
Jesus Christ on a cracker. I hate paypal. Oh well, I'll work with it.
1.55 cu ft. is actually too large, per the website. For the FI Q 12 you can have a sealed enclosure ranging from .8 to 1.5 cu ft. Mine enclosure is closer to approx. 1.3 cu ft. of usable airspace.
I guess I should've specified that I'm going to be trying to fall into the larger end of their box volume spec, but that 1.55 ft^3 was not subtracting the displacement of the driver. So I should fall somewhere close to your same usable air space. That being said, I was only using the 1.55 as a "general" figure to help me plan my install, it won't be easy nor will I know exactly how close I can get to that till I have my interior torn out and take some final measurements.
It hits the higher bass notes real tight, since it's a sealed enclosure. At the same time, it'll dip into the 20 something hertz range also. Either way the sub reproduces the notes extremely clear. Just make sure you have absolutely no leaks in your enclosure...
Those damn sealed enclosures can be so pesky about, well, actually being sealed. lol
Old Jan 24, 2008 | 06:44 AM
  #204
350zspl's Avatar
350zspl
i prefer 80 hertz on the amp and LP on HU off
at 55 on your amp you are filtering out quite a bit of midbass
if what you did sounds best to you that is important
it is preferance , but i like 80 as i like more mid bass
Old Jan 24, 2008 | 06:46 AM
  #205
VO...'s Avatar
VO...
Administrator
Yes sir
  #206
clarkemtp's Avatar
clarkemtp
either will be better than a W6
No doubt. lol
fi Q 12" .8 to 1.5 net dual 1 or dual 2 1000 rms $ 259 shipped
fi ssd 12" .8 to 1.6 net dual 1 or dual 2 800 rms $ 189 shipped
look at what i am posting , match your rms, budget, and net sealed space to pick the correct woofer for your best results
I've pretty much decided on the FI Q 12". I should be able to easily accomodate the box volume requirements. Now, to find an amp to match it well. Oh, and if you sell 'em, I'll definitely shoot you a PM when I'm ready to order in a few days.
Old Jan 24, 2008 | 06:51 AM
  #207
VO...'s Avatar
VO...
Administrator
I'm not a big fan of midbass. Actually, what my front door speakers kick out is fine with me..
Old Jan 24, 2008 | 06:52 AM
  #208
clarkemtp's Avatar
clarkemtp
I have a Pio HU, the D3, and my HU has the same adjustability. BUT... it's not a LP filter on the sub outs. The setting is actually an adjustable high-pass filter affecting the front and rear speakers outs/rca's.
So, he's actually NOT "double" filtering the sub outs in both the HU and at the amp, as it would seem. Well, at least not if his Pio HU works like the D3 does... which I suspect it would.
Old Jan 24, 2008 | 06:54 AM
  #209
VO...'s Avatar
VO...
Administrator
Just a real life observation. My Rockford P8002 is rated at 800 watts RMS @ 4ohms on 1 chn. It has more than enough power to push the FI Q. IMO, it actually has more "umph" than the speaker needs. Other brands of amps may differ though, in regards to true power output...
Old Jan 24, 2008 | 06:59 AM
  #210
350zspl's Avatar
350zspl
they accept Visa , MC , Amex i sure
Old Jan 24, 2008 | 07:05 AM
  #211
350zspl's Avatar
350zspl
No doubt. lol
my favorite amps are
US Amps
Zed Amps
McCintosh Amps
CDT Amps
RD Audio Amps
Sundown Amps
Digital Design amps
either choice is a winner
i would get a DVC 2 ohm sub and run @ 1 ohm
use a 1 ohm stable amp
i get RD for the low low
hifonics amps for SPL and stetsom as well
Old Jan 24, 2008 | 07:07 AM
  #212
350zspl's Avatar
350zspl
that is why your happy with your settings
your fine
no worries
for me i can't run at 55 hertz , cause it will meter lower DB
i use 80 hertz daily on my LP
at competition i raise my Lp to 125 hertz
this is the loudest
Old Jan 24, 2008 | 07:09 AM
  #213
VO...'s Avatar
VO...
Administrator
your fine
no worries
this is the loudest
  #214
350zspl's Avatar
350zspl
i use a D3 as well
on the d3 sound settings you have a HP filter , you have a subwoofer icon that allows another LP setting, you also have an eq icon that allow for low , mid and high setting and here on the low you can go to 40 hertz if you want
Old Jan 29, 2008 | 01:13 PM
  #215
VO...'s Avatar
VO...
Administrator
I had no idea my thread would have caused such a big impact. FI should send me some freebies...
Old Jan 29, 2008 | 05:54 PM
  #216
clarkemtp's Avatar
clarkemtp
Somebody had to be the Z33 guinea pig.
Old Jan 30, 2008 | 06:18 AM
  #217
VO...'s Avatar
VO...
Administrator
Old Jan 30, 2008 | 06:22 AM
  #218
peaches05's Avatar
peaches05
hey guys, i was thinking about getting an fi q 10 (1000 rms) after reading this thread and was wondering if this amp would be ok with it
http://www.sonicelectronix.com/item_...BXi+1206D.html
thanks for your input guys
ps. they really should give you some kickbacks vo
Old Jan 30, 2008 | 06:38 AM
  #219
StreetOC192's Avatar
StreetOC192
If you got the dual 2ohm sub and wired it in parallel to 1ohm, that amp will get the job done. For the price it might be hard to beat.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Twenty4
Jan 17, 2016 01:20 PM
