Audio Builds Audio projects and builds from my350z members
My audio setup, the installation begins
Old 04-22-2009, 06:39 PM
adamtaylorpcb
adamtaylorpcb's Avatar
use 3/4 to prevent any flex stuff it with poly and your set
Old 04-23-2009, 03:22 PM
XERMAN2001
XERMAN2001's Avatar
(i just edited my post)
i dont want to make the box any taller than 5.75 inchs or this would end up raising the floor level higher than before. So if i make it out of 3/4 inch mdf i would have to make the bottom of the box out of fiberglass to contour to the floor and leave enough room to clear the sub. I would also need to add poly, the box would be around .64 cubic sq feet and i need .75 cubic sq feet. how much poly would i need to add?
Old 04-23-2009, 03:42 PM
XERMAN2001
XERMAN2001's Avatar
i just called the infinity tech line, they said that with the amp and sub that i am using 1/2 mdf should be fine. They said when you are running some of their higher end stuff 500 rsm plus you need 3/4 inch, i am going to be running at 250 rms.
Old 04-23-2009, 03:54 PM
michaeljr6
michaeljr6's Avatar
why don't you put the amps inside the glove compartment and where the stock sub is?
Old 04-23-2009, 05:54 PM
XERMAN2001
XERMAN2001's Avatar
i am looking for something with a bit more show. I want show but still usable storage space. If i wanted just show i would have done some sort of fiberglass enclosure on top of the floor and lost all cargo space. If i wanted just sound and didn't care about show i would have put the sub in the stock sub located and the amps in the glove box behind the passenger seat.
my inspiration:
link to his build https://my350z.com/forum/audio-build...done-pics.html
another one
link to his build https://my350z.com/forum/audio-build...ll-for-ya.html
another one
Old 04-26-2009, 07:14 PM
XERMAN2001
XERMAN2001's Avatar
worked on the amp mounting area some more
amps in
sub and amp trim rings. See the blue lines, the inside or the part closer to the amps and subs will be see when the final trim panel is on. I am thinking of making the this inside part silver, the rest will be black. The outside part will support the final trim panel or false floor panel.
Old 04-29-2009, 08:32 AM
adamtaylorpcb
update kneegrow
build some shiz out of wood not cardboard
Old 04-29-2009, 08:42 AM
Goku350z2007
Goku350z2007's Avatar
what are you going to do when you get a flat tire?
Old 04-29-2009, 05:17 PM
adamtaylorpcb
same thing i do, call my insurance for free towing or a spare
Old 05-09-2009, 09:32 AM
blaze0303
blaze0303's Avatar
Keep it up man, I wish i had the patience to fat mat my ENTIRE car.
Old 05-09-2009, 01:43 PM
Mike Wazowski
Mike Wazowski's Avatar
very nice
Old 05-23-2009, 09:44 PM
J's 350z!
J's 350z!'s Avatar
Where did you get the second glove compartment door for behind the driver seat?
Old 05-24-2009, 05:12 PM
Blazemaster
Blazemaster's Avatar
for those that did their own sound deadening with things like fat mat or dyna mat before, did you guys only did the actual bare metal? I did some on the bare metal, but I spent most of my time on the individual plastic interior pieces that came out of the trunk. I bought 64 sq. feet of elemental design's edead 80. Looking at this thread, makes me think that I should go back and put more on the bare rear strut. It makes more sense because the bare metal are connected to the frame and are more likely to resonate through the bumps on the road. I still have about 20 sq. feet left, I think I will use the rest on the actual rear strut, not the plastic pieces. I have to order at least another 50-100 sq. feet, if I want to do the floor, doors, and ceiling.
Old 05-24-2009, 05:26 PM
JAM3Z
Phenom
JAM3Z's Avatar
Nice work!
Old 06-07-2009, 09:56 AM
ncparamedic
Prodigal Son
ncparamedic's Avatar
ok, any update?
Old 06-08-2009, 05:23 AM
ETZ
ETZ's Avatar
Hey XERMAN2001 what kind of speaker wire are you using,also for the 2nd glove box were you able to get the lock coded to the original key?
Old 08-11-2009, 03:39 PM
XERMAN2001
XERMAN2001's Avatar
I am using Stinger 14 gauge wire for the speakers and Moster cable 10 gauge for the subs.
About the key, i guess i could but ive not.
Old 08-11-2009, 03:40 PM
  #38
XERMAN2001
XERMAN2001's Avatar
UPDATE
False floor
covers on, so i can use the trunk/hatch
carpet on
Old 08-11-2009, 03:43 PM
  #39
XERMAN2001
XERMAN2001's Avatar
pulled everything out ---
AND ---------------------------!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-11-2009, 04:04 PM
  #40
XERMAN2001
XERMAN2001's Avatar
time to reproduce the cardboard templates to MDF
The sub box, screwed, glued and cocked
The amp rack
Amp trim panel
Sub trim panel -- with a rounded iner edge
Quick Reply: My audio setup, the installation begins
