Audio Builds Audio projects and builds from my350z members
My audio setup, the installation begins
Old Aug 11, 2009 | 04:07 PM
  #41
XERMAN2001's Avatar
XERMAN2001
The false floor, or top trim panel. -- With a rounded inner edge.
The filler panels, so i can put weigh over the amps and sub when using the trunk/hatch.
I used a rotor to remove MDF so i could counter sink the metal mesh. I stapled then used cocking to secure the mesh. Then i painted it all black.
MORE UPDATES SOON
Old Aug 11, 2009 | 04:09 PM
  #42
Mike Wazowski's Avatar
Mike Wazowski
lookin good
Old Aug 16, 2009 | 05:02 PM
  #43
DBTre50z's Avatar
DBTre50z
Looks good. Looking forward to some updates.
Old Sep 1, 2009 | 09:09 AM
  #44
XERMAN2001's Avatar
XERMAN2001
UPDATE: September 1st 2009
For added strength I coated the sub box with fiberglass resin.
I painted the front the will be seen black.
wrapped the amp trim panel and sub trim panel in grey vinyl.
An idea of what it will look like.
I didn’t want to drill any holes in the cars floor so I came up with a way to avoid it.
I made a bracket to attach the sub box to the spare tire mount. On the other side of the box I used a bracket and a screw into the metal, but not the floor.
The amp “rack, or mounting platform” is attached to the car using 3 brackets that I bent and cut, bolted to existing mounting points.
The other side is screwed into the box.
Old Sep 1, 2009 | 01:19 PM
  #45
ProperID's Avatar
ProperID
Originally Posted by XERMAN2001
Raped the amp trim panel and sub trim panel
Lol @ rape!
on the progress.
Old Sep 1, 2009 | 04:25 PM
  #46
XERMAN2001's Avatar
XERMAN2001
Originally Posted by ProperID
Lol @ rape!
on the progress.
it said no, but i said YES!!! lol -- fixed
thanks
Old Sep 12, 2009 | 07:57 AM
  #47
adamtaylorpcb's Avatar
adamtaylorpcb
Rapped the amp trim panel and sub trim panel in grey vinyl.
Wrapped is the word your looking for
Old Sep 12, 2009 | 10:19 AM
  #48
XERMAN2001's Avatar
XERMAN2001
ha ha, i still failed. oh well fixed
Old Sep 12, 2009 | 10:31 AM
  #49
quakerroatmeal's Avatar
quakerroatmeal
It took a entire year for an audio system install? Longest install I've ever seen.
Old Sep 13, 2009 | 05:48 AM
  #50
adamtaylorpcb
you have apparently not done an in depth install yourself while going to college full time and working..... regardless, who is ever really "done" with a audio install?
Old Sep 13, 2009 | 09:23 AM
  #51
quakerroatmeal
I've done plenty of "depth" install. While I understand it takes time..but maybe I'm just very impatient/overly excited. I wouldn't be able to wait 1 year to install the equipment that I already have.
Who is ever really done with an audio install? Plenty of people..
Maybe I just have more time then others while in college and working as well...
Old Sep 13, 2009 | 08:36 PM
  #52
XERMAN2001's Avatar
XERMAN2001
i started a year ago but didn't touch it during the winter. So its taken 6 months which is a very long time, i was impatient/overly excited and wanted it to be finished 5 months ago but i don't have much free time and it took ALLOT longer than i though it would.
Old Sep 13, 2009 | 10:28 PM
  #53
gsxrsellout's Avatar
gsxrsellout
mine took 3 months almost and well over 100 hours to do. I was gone for about a month during that time but sometimes things don't go as planned. Eventually I'll do a build similar to yours in my trunk. Keep up the good work!
Old Sep 16, 2009 | 11:44 PM
  #54
Lug's Avatar
Lug
Thanks for starting this thread XERMAN2001 - Lots of great info and ideas contained within it. So great in fact that I'm using this thread as a "DIY" audio install for my Z!
I ripped out all the rear panels last weekend and started installing the fatmat today. Man this stuff is sticky and time consuming to install. It doesn't help that everytime I go outside to install the fatmat it starts to rain... *looks up and shakes fist*
I decided to go with pioneer components over infinity.
Headunit: Cant afford yet
Front stage Speakers: PIONEER TS-C720PRS
Rear stage Speakers: Pioneer TS-D720C
Front and Rear Amp: Pioneer PRS-D4200F
SUB: Pioneer TS-W2502D4 10"
SUB AMP: Pioneer PRS-D2200T, or Pioneer PRS-D1200M
Anyhow, keep up the good work and keep posting pics of the build. Its looking great!
Old Sep 19, 2009 | 08:26 AM
  #55
XERMAN2001's Avatar
XERMAN2001
yes the Fatmat is very time consuming to install. I am almost done, finally. I am now having to battle colder temps and less daylight here. I am glad i could help you out a bit on your project. I wanted front components but didn't have the money at the time, i may replace them with components in the future.
good luck with your build
Old Sep 22, 2009 | 05:21 PM
  #56
XERMAN2001's Avatar
XERMAN2001
UPDATE SEPT 21ST --------- THE AUDIO PROJECT IS FINALLY DONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
amps installed and wired
time to wrap the grills/covers in speaker cloth.
The cloth is glued to the mdf on the back, then i stapled black vynal on top of that.
Old Sep 22, 2009 | 05:29 PM
  #57
XERMAN2001's Avatar
XERMAN2001
onto the vinyl, time to wrap it.
i used water based contact cement to adhere the vinyl to the MDF. Then i used a heat gun to wrap it around and staple it to the back.
top piece done
sides
sides done
middle
middle piece done --- this piece was allot more difficult than the other 2
Old Sep 22, 2009 | 05:49 PM
  #58
XERMAN2001's Avatar
XERMAN2001
The finished product ----
with the carpet on, only 1/2 inch higher than stock. looks stock and can still be used just like it was before.
with the car off, showing the black vinyl and grills/covers.
with the grills out, showing the grey vinyl amps and sub.
flash on --
flash on --
flash on --
Old Sep 22, 2009 | 05:58 PM
  #59
XERMAN2001's Avatar
XERMAN2001
MORE PICS with the grills out, showing the grey vinyl amps and sub.
flash on --
flash on --
flash on --
flash off --
flash off --
flash off --
Old Sep 22, 2009 | 06:02 PM
  #60
XERMAN2001's Avatar
XERMAN2001
close up pics---
flash on --
flash off --
I ALSO INSTALLED A BLUE LED LIGHT, PICS COMING SOON
