Audio Builds Audio projects and builds from my350z members
First time installer
Old Apr 7, 2009 | 08:28 PM
Patrickn210's Avatar
Patrickn210
Default First time installer
Allright, so let me start out by saying that I've never done any audio work before which means I'm really quite noobish at this which means I'm gonna ask some really noobish questions so bear with me
I have a 2004 base model, stock everything, non bose
I want to try and keep this simple and not too expensive, so I'm just looking at getting a new deck and changing out the door and rear speakers. No subs.
I'm thinking about buying a PIONEER FH-P8000BT, and for the speakers I've heard good things about the Infinity 6022SI's.
So as far as I know, that is all I'm buying, the Pioneer, and the 4 speakers, and whatever comes with them in the box. I don't know that I need anything else other than tools?
So this is where it gets really noobish lol
I've seen some tutorials on how to remove all the necessary panels so I think I should be allright on that, at this point I'm just curious about wiring and power. Is it as simple as going in to my car, taking out my old stuff and putting the new stuff in? Will I need to do any new wiring, is an amp going to be needed for any of this?
Any help is greatly appreciated, thanks
Old Apr 8, 2009 | 04:51 AM
sintaxeror's Avatar
sintaxeror
You will be fine without an amp... so it really will be as simple as taking the old stuff out, and installing the new stuff.
The only new wiring you will need is the pioneer harness adapter so your new stuff will plug right into the factory interface. Also, since your speakers are 2-way, you can use the factory wires to connect them, but you will want to just disconnect the front factory tweeters.
You will also need a dash kit so that the headunit fits nice and flush in the dash.
Overall, it should be pretty simple -- good start for a first install.
Old Apr 8, 2009 | 08:37 AM
Patrickn210
sounds good, I found the harness adapter online so I'll get that too
I'm just curious about the dash kit. I was lookin on crutchfield and its telling me that it would send me this dash kit with the headunit I'm ordering (pic attached)
Is that supposed to work with the PIONEER FH-P8000BT, cause it looks like a single din with a little cubby underneath, unless the cubby and middle piece going across is removeable?
Also, I've heard a few people say that its better to just invest in really good door speakers and take the rear ones out. I was messin around with my stock system today and even with the stock it does sound pretty good when I adjust it to only the front speakers. Any suggestions?
Old Apr 8, 2009 | 10:22 AM
adamtaylorpcb's Avatar
adamtaylorpcb
the little trim peice infront of the pocket is what you will use
yes 100% get better door speakers and ditch the rears
Old Apr 8, 2009 | 11:18 AM
sintaxeror's Avatar
sintaxeror
Re: Dash kit
You don't use the little pocket, and you snap off the middle divider and file the sides smooth.
Re: Rear Speakers.
I also do not run rear speakers.
Old Apr 8, 2009 | 08:24 PM
Patrickn210
Allright, I think I'll just go with the front speakers then. Since I'm not using the rear ones, do I just disconnect the wiring at the speaker? And should I disconnect the tweeters as well or keep em in?
Old Apr 9, 2009 | 07:55 AM
sintaxeror's Avatar
sintaxeror
Don't bother disconnecting the rear speakers, just fade the sound all the way forward... if you really want to disconnect them, don't connect the rear speaker wires on your new headunit wiring harness, but I would just connect them and fade all the way forward, if for some reason in the future you need to use your rear speakers.
I would also leave the stock tweeters in, but just disconnect them. Its easy, you will see when you get the door panel off.
Old Apr 9, 2009 | 08:44 AM
adamtaylorpcb
^^^ word
Old Apr 9, 2009 | 04:45 PM
Patrickn210
you guys have been a huge help, thanks for everything
me likey this site lol
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
