Audio Builds Audio projects and builds from my350z members
Finally Done JL10W7, Xbox in the Dash & much more
Old Jul 26, 2004 | 11:50 AM
Phatmitzu's Avatar
Phatmitzu
Originally posted by cehome
WOW. That looks EXPENSIVE.
^ No doubt! Very sweet setup.
Old Jul 26, 2004 | 12:17 PM
leemik's Avatar
leemik
WOW I wanted to do something like that for my xbox however, I thought there was a limit to how long the IDE cable could be?? So how long is your IDE cable?
--mike
Old Jul 26, 2004 | 01:12 PM
LaPuLaPu's Avatar
LaPuLaPu
IMHO, by far the best setup I've seen in a Z. OUTSTANDING JOB!
Old Jul 26, 2004 | 02:13 PM
nissan_fanatic's Avatar
nissan_fanatic
--mike
Boy if you only knew how much time and effort went into this one, I went back and forth on it. As you probably know the industry standard is 18" but the longest production IDE cable is 48". Unfortunately I needed something like 72" to put the Xbox in the back compartment. I actually found a company in Raleigh that makes custom lengths, I had them make me a 72" ide but the Xbox didn't see the drives. I tried a 48" cable and the Xbox still didn't see the drives but when I tried the 36" cables everything worked. 36 inches was just long enough to put the Xbox in the passenger side and still reach the dash. The 1st connection has to be the DVD ROM drive, it's weird. Xbox uses Cable Select but even when I tried Master & Slave and the appropriate jumpers it only worked one way. Sorry for the long answer when the short one was 36" but if you are planning on doing something similar I thought I would give you a heads up.
Old Jul 26, 2004 | 02:14 PM
nissan_fanatic
Thanks guys for all the compliments. So being without my car for 10 weeks was worth it
Old Jul 26, 2004 | 02:51 PM
leemik's Avatar
leemik
Thanks so much for the info.. Here is a little bit of info that I learned... I have two xboxes.. one for home and one for my car.. The one I have at home is an older V1.0 Xbox and I was able to do master-slave on it.. The newer one in my car I could not..
--mike
Old Jul 27, 2004 | 12:41 PM
blackmumba's Avatar
blackmumba
where can i find out how to upgrade my xbox to do all this other sh*t you guys are talking about i didnt even know that more stuff could be downloaded into it.
Old Jul 27, 2004 | 12:54 PM
leemik's Avatar
leemik
http://www.xbox-scene.com
read this entire site and you will be enlightened
Old Jul 27, 2004 | 03:41 PM
nissan_fanatic
--mike
weird the one in my car is a v1.0 Anyway, glad it worked for you
Old Jul 28, 2004 | 08:28 PM
kosta157's Avatar
kosta157
sick install, looks like the shop dod a very good job.
how much was the cable? and if i send you some cash can you have one made for me i am doing something similar but i have to put mine in the pocket where you have your screen and i am also going to be outfitting it with a center channel speaker but my project won't get started till september.
Old Jul 28, 2004 | 08:30 PM
kosta157's Avatar
kosta157
one more question is it the hard drive that has to be 36" and the tray can be whatever length or does it have to be equal 36" and 36"??
Old Jul 29, 2004 | 12:07 AM
AzianToby's Avatar
AzianToby
That is Freakin Nutts!!! You are the MAN!
Old Jul 30, 2004 | 10:34 AM
nissan_fanatic
It's actually one cable with 3 IDE connections, there is only one slot on the Motherboard. The DVD rom drive will need to be the 1st connection, then the HD second using cable select.
Since a 36" cable is a production cable just pick up any 36 IDE cable, they should have all at least a total of 3 IDE connections (1 for the MB, and then 2 for your IDE drives)
Let me know if you have any more questions.
Old Jul 30, 2004 | 11:08 AM
toykilla's Avatar
toykilla
Son of a Bit@h.. that is almost EXACTLY the setup i was designing.. grrrrrr you beat me to it.. back to the design board
(good job.. looks great)
Old Jul 30, 2004 | 11:48 AM
NismoKid's Avatar
NismoKid
Wow, you've done an incredible job! I'm looking to buy an Xbox for my car in the next few months, but I'm still seeing how I want to install it. I never thought of relocating the DVD drive since I thought I'd upgrade the HD to hold rips of games and DVDs. So it's 36" from the empty space behind the driver seat to the dash?
Old Jul 30, 2004 | 01:53 PM
nissan_fanatic
Just curious, which part? The Sub box, the Xbox DVD ROM or the door speakers?
I wish, that would have required a 72" IDE cable which the Xbox didn't recognize the drives. A 36" cable was exactly long enough for mounting the Xbox in the passenger side area below the dash.
Old Jul 31, 2004 | 05:12 AM
toykilla's Avatar
toykilla
all of the above
great minds think alike.
Old Jul 31, 2004 | 10:38 AM
  #38
ZYAL8R808's Avatar
ZYAL8R808
I only have one problem with your mods,
IT MAKES ME JEALOUS!!!
Nicely done.
Old Jul 31, 2004 | 07:57 PM
  #39
rplink's Avatar
rplink
How do the mids in the door pods sound? I'm trying to decide if I want to build a set for my 6.5 Eurosport mids.
Are they completely sealed or do they vent to the stock speaker grill opening?
Old Aug 1, 2004 | 01:32 PM
  #40
nissan_fanatic
They sound awesome. They vent into the stock speaker grill openings, they were removed so the speaker would fit.
