Audio Builds Audio projects and builds from my350z members
Finally Done JL10W7, Xbox in the Dash & much more
Old Aug 1, 2004 | 05:43 PM
  #41
NismoKid's Avatar
NismoKid
Alright, I have a question on how to get the Xbox signal to make it over 3' wires.
I don't know what kind of wires the Xbox uses or the possibilty of this, but could you use amplifiers to make the signal travel further? I know telephone companies sometimes use "coils" to allow signals to travel further, which are basically amplifiers. Sorry if my question is stupid because I don't know much (if anything at all) about wiring.
Old Aug 2, 2004 | 03:22 PM
  #42
peanuthead's Avatar
peanuthead
You should get the XIR chip for the XBOX remote to turn the box on and off with the remote.
search google for "XIR remote" . . . they're like $4
Old Aug 2, 2004 | 03:41 PM
  #43
nissan_fanatic's Avatar
nissan_fanatic
That's part of the beauty of the install, I had the power control buttons moved to the center console, the pics didn't come out very well but I literally had the front panel removed with the buttons to the center console, so I don't need that chip. Thanks for the suggestion though
Old Aug 2, 2004 | 03:46 PM
  #44
nissan_fanatic
??? not sure what three wires you are referring to but basically an Alpine Aux apapter was installed that had 4 imputs for RCA's. 1 for the TV tuner and 1 for the Xbox and 2 extra for what ever I decide to do next. Hope that helps
Old Aug 2, 2004 | 04:00 PM
  #45
NismoKid's Avatar
NismoKid
Is there any kind of wire on the market that amplifies signals (has an amplifier, not the audio kind)? Maybe this could be used for the Xbox relocation.
Old Aug 4, 2004 | 07:07 PM
  #46
drdisco's Avatar
drdisco
Great install. I can't imagine what that all cost. What is the material they used on the inside of the sub enclosure? It seems to work well with the neon glow.
Old Aug 4, 2004 | 09:18 PM
  #47
ROME's Avatar
ROME
Wow thats clean. Was there any problems with airspace in the speakerbox?
Old Aug 5, 2004 | 06:21 AM
  #48
andycapp's Avatar
andycapp
What linux software are you running on the xbox?
Old Aug 5, 2004 | 08:25 AM
  #49
teh215's Avatar
teh215
It looks like your shifter **** is not on straight...
Old Aug 8, 2004 | 06:06 AM
  #50
nissan_fanatic
I fixed that problem, I installed a new shift ****. But to answer your question, yes it was crocked. They lost the gold bushin during the install and it wouldn't lock into place. I already had this other shift **** before the install just hadn't installed it until now.
That is MDF sanded and painted. They did a great job
Thanks, not problem what so ever. The box is actually pressure sealed. It had to be because of my requirements of how I wanted to see all the way through the box and I wanted plexiglass in the back so I could see the magnet of the sub.
None yet, still experiementing. I barely got the xbox modded in time for the install so I hadn't had all whole lot of time. Still trying to figure out how to copy whole DVD's to the Xbox so it's in one file, instead of a bunch of file. I got it figured out with the games, just not the DVD's yet. If you know please tell me know
Old Aug 8, 2004 | 06:09 AM
  #51
nissan_fanatic
Nismokid,
To be honest I am not quite sure what you are asking. I think you are a little confused about something. There is a lot more that just extending the RCA's, you still have to run IDE cables and power cables to the drives themselves. The RCA's is the easy part. Hope this helps.
Old Aug 15, 2004 | 03:55 PM
  #52
Dragonstyle's Avatar
Dragonstyle
Damn...thats sick!!....
Old Aug 16, 2004 | 06:27 PM
  #53
nissan_fanatic
Thanks,
I was able to get a better picture of the power on/off buttons.
Old Aug 16, 2004 | 08:06 PM
  #54
murrman100's Avatar
murrman100
Originally posted by nissan_fanatic
Thanks,
That is fantastic!
I removed my custom PC and I was thinking of replacing it with an Xbox of PS2. It looks nice and clean.
Thanks for the pics and inspiration.
Old Aug 17, 2004 | 10:48 AM
  #55
suse's Avatar
suse
How did you get the xbox cdrom in the dash like that?? That is sick!!!
Old Aug 19, 2004 | 02:51 PM
  #56
nissan_fanatic
Thanks. It's a double DIN so I just used the second DIN for the Xbox. All the cables were just extended. Don't try anything longer than a 36" IDE cable, wouldn't work for me.
Originally posted by murrman100
That is fantastic!
Thanks man. Hit me up if you have questions. Why did you remove your PC?
Old Aug 19, 2004 | 07:35 PM
  #57
James1871's Avatar
James1871
I think that's what nismokid was referring to, what did u use to extend the IDE cable... i'm in the process of doing pretty much exactly the same thing you did in your dash in an A4 dash and i need length so i can have a location to stuff the actual xbox. what components did u upgrade on the xbox (like what size drive and what mod chip), i'm doing dual drives so i can burn music and dvds from the car also.....
Also you said you can park in your garage and FTP files, did u use a wireless card and how did u hook that up.... sorry for the long post
Old Aug 20, 2004 | 04:38 PM
  #58
QikTimez's Avatar
QikTimez
Thanks,
Well done. The power on/off buttons are a beautiful touch.
Old Aug 29, 2004 | 02:37 PM
  #59
nissan_fanatic
Sorry for the delayed respone, been on vacation with no internet access which killed me.
As for extending the IDE cable, I don't really recommend it, my boss fried his motherboard trying. Just buy a 36" IDE cable. Again I tried a 48" cable and it didn't work for me but I didn't have a lot of time to test. 48" wouldn't recognize the drives.
The HD is a 120 GB, but can support up to like 4 terabytes now so basically buy as big of HD as you want. The dashboard on the Xbox is evolutionX. The mod chip is the smartX Click here. I like the chip, go with soldered instead of solderless defintely. Go to Xbox scene link to read up, a lot of info on that site. The wireless card is the Xbox wireless adapter. It has a G radio (capable of up to 54K as appossed to a B radio only capable of 10K) and I have a G wireless router. I actually have the microsoft router and I am very pleased with it and is the same price as linksys.
Hope this helps answer some of your questions and let me know if you have more.
Old Aug 29, 2004 | 02:41 PM
  #60
nissan_fanatic
Thanks man. If you only knew how much grief that caused me and the stereo shop, at first it didn't look like it was going to be possible but I just kept stressing to them we had to come up with a way to move those buttons. With the mod chip you really access to both buttons, the bottom button boots into the mod chip, the top boots like a normal Xbox. Not only that, I had to have access to eject the DVD rom tray as needed.
