S2K Engine Start Button install write-up
Old Nov 29, 2006 | 05:53 PM
  #101
Kam350z's Avatar
Kam350z
leemik you have such an awesome Z
Old Dec 15, 2006 | 09:16 AM
  #102
blackznismo's Avatar
blackznismo
ONE of the best write ups i've ever seen....just did my own....damn body panels....thanx man...
Old Jan 3, 2007 | 09:33 PM
  #103
TotalChaos's Avatar
TotalChaos
I like that one on the door panel Pratt... That may be a possiblity
Old Jan 10, 2007 | 01:38 AM
  #104
JKC350z's Avatar
JKC350z
A. tap the wire like you did the other one (this allows the car to start with either the key or the button).
B. Cut the wire and make the connection on the starter side and tape up the cut end leading to the connector. (this disables the key from starting the car and makes the button the only way to start it).
can someone explain the difference in these two....i know in A, you either splice into the wire or plug it into the harness, but in B what do you mean by the "starter side"?
Old Jan 10, 2007 | 05:40 AM
  #105
THE TECH's Avatar
THE TECH
The "starter side" is the end of the wire that you just cut that leads to the starter.
Old Feb 7, 2007 | 05:53 AM
  #106
Acree's Avatar
Acree
Just to bump this thing back up, in the next month or so, I will be finishing my carputer. I just bought a blue push button switch from http://www.ignitedperformance.com/index2.html. It will be integrated into my center console along with a thumb print reader, motorized nav door, touch pad, new stereo, etc.
I will post up a review once I receive the product and get it installed.
-Acree
Old Feb 8, 2007 | 07:05 AM
  #107
MustGoFastR's Avatar
MustGoFastR
Sweet; can't wait to see it!
Old Feb 8, 2007 | 01:55 PM
  #108
Ep3's Avatar
Ep3
i saw one the other day the button was right in the middle of the shift ****... like the nismo onesliiked good
Old Feb 9, 2007 | 11:55 AM
  #109
Greg'Z33's Avatar
Greg'Z33
I've got an alternate idea for the '06 6MT 350Z which has a different center console and that is this: Make the hazard swith an "Engine Start" button. Relocate the hazard switch to the blank plate next to my heated seat switches using either a TCS or VDC OFF switch. I think I'll tackle this after I move from Florida to Texas in the next couple of weeks.
Old Feb 11, 2007 | 09:20 PM
  #110
usmanasif's Avatar
usmanasif
I took a peek under my shifter trim piece today, only to notice that although the location below the stereo is ideal for a push start, it will not work with an '06. Our hazard switch assembly has a mounting screw right there. I am pissed.
Greg, are you sure your method will work? Not that I am considering it as an option, but since the hazard button is a push-on/push-off, won't it keep the starter circuit closed until it is pushed a second time? One would have to release the clutch a millisecond after pushing the hazard switch or starter would grind due to the constant pulse. Is that correct?
Old Feb 12, 2007 | 05:31 AM
  #111
Greg'Z33's Avatar
Greg'Z33
Greg, are you sure your method will work? Not that I am considering it as an option, but since the hazard button is a push-on/push-off, won't it keep the starter circuit closed until it is pushed a second time? One would have to release the clutch a millisecond after pushing the hazard switch or starter would grind due to the constant pulse. Is that correct?[/QUOTE]
Of course, you're right. I would have to somehow disable the mechanism in the switch to change it from a pushbutton ON/OFF to a momentary "ON" type switch. I haven't disassembled one yet but I'm sure I can do it. As far as using a VDC or TCS switch as the new hazard switch, I would probably use an 03-05 type hazard switch instead and just place it in the blank plate next to my heated seat switches. When I do mods like this, my goal is to keep an OEM flavor. Check out the following link (and post #55) for pics of another project I've been working on (still trying to get it where I want it):
https://my350z.com/forum/forced-induction/184829-my-oem-style-boost-gauge-project-3.html
Greg
Old Feb 12, 2007 | 07:24 AM
  #112
usmanasif's Avatar
usmanasif
That gauge looks awesome! Your kung-fu is indeed stronger than mine
I just got another idea of how to make this work. Z is currently in hibernation, but in a month or two, i am going to get cracking on that. Will post pics.
Old Mar 14, 2007 | 07:28 AM
  #113
THE TECH's Avatar
THE TECH
Do you know the functions of the three wires coming from the actual switch? (red. yellow, black). I am changing my setup and am going with a different switch and need to see if i can just use the three wires (red, yellow, black) directly to the new switch (I assume that these switches function the same).
Old Mar 21, 2007 | 11:41 AM
  #114
Christian88's Avatar
Christian88
Default Just Installed...
I had ordered my S2K Engine Start Button about a month ago, but hadn't installed it yet since I wasn't sure where I wanted to put it. I wasn't so crazy about the gap it left on those that installed in above the shifter, so I looked for another place. Since the S2K's button is left of the steering wheel, I wanted mine there also...
So that's where I decided to install it. Like everyone has said, it is a really simple install thanks to the great writeup. It took under an hour. The most time was cutting the hole for the button. I wanted it to be as exact as possible and I didn't want to f-up my dash. The one draw back about where I put the button was that I had to go through two levels of plastic dash, the surface one and another about an inch behind it...but it made it even more secure. I didn't have to wedge it with elastic bands behind it since it fit so snug into the dash. Anyway, here are some pics of the finished product...
Again, thanks to all those who posted before me with instructions and how-to's!
Old Mar 21, 2007 | 11:43 AM
  #115
Mike Wazowski's Avatar
Mike Wazowski
looks good. I think I am going to place mine in the center console.
Old Mar 21, 2007 | 11:52 AM
  #116
Christian88
I wanted to put it in the center since it's more visible, but I just couldn't get past that gap that everyone had. Plus my center console is about to head to Cali to get painted Silverstone.
Old Mar 21, 2007 | 11:56 AM
  #117
Mike Wazowski
Im talking about the one between the seats
Old Mar 21, 2007 | 11:59 AM
  #118
Christian88
I thought about there too. That would have been my second choice next to where I put it. Good luck with the install...Beautiful Car!
Old Mar 21, 2007 | 12:00 PM
  #119
buzzardmountain's Avatar
buzzardmountain
Looks good Christian88, I like the location.....
Old Mar 21, 2007 | 12:06 PM
  #120
Christian88
Thanks! I appreciate the feedback!
