Write-up: My solution to the stock sound-blocking door speaker grills
Old May 18, 2007 | 06:04 AM
  #41
sixsigmalarry's Avatar
sixsigmalarry
Question Glue still working out?
MustGoFastR,
AWESOME WRITE UP!
240Zplus110,
Is the 3M glue still holding up?
Originally Posted by 240Zplus110
Sourced the speaker cloth from an auto uphostery shop -- cost $5. They recommended 3M spray glue #76 (IIRC) to attach to the plastic.
Long story short.. I used this DIY to convert my speaker covers, Dremel tool and all. I used the spray glue on both the front and rear edges, stretched the fabric on while the glue was still tacky. I then trimmed the excess.
So far eveything is holding... after one cold rainy day
Thanks for the effort to post your work and the inspiration to do mine!!!
Cheers.
THANKS!
Old May 18, 2007 | 09:39 AM
  #42
VO...'s Avatar
VO...
Administrator
I ordered the grill cloth yesterday from PartsExpress.com . I'll post pics when I finish the mod next week.
Old May 18, 2007 | 10:09 AM
  #43
harrieyu's Avatar
harrieyu
hey..can the plastic be cut with anything else? besides a dremel?
Old May 21, 2007 | 10:13 AM
  #44
VO...'s Avatar
VO...
Administrator
I'm sure it could, but the real question is: Is it really worth all the hassle and elbow grease doing by hand with a box cutter or exacto knife, when you can acquire a new tool and cut it effortlessly?
Which reminds me, I just bought a Husky phnematic cutter. Cuts at 20,000rpm!!! Hell, I could cut through prison bars with that thing.
Old May 21, 2007 | 03:09 PM
  #45
240Zplus110's Avatar
240Zplus110
Originally Posted by sixsigmalarry
MustGoFastR,
AWESOME WRITE UP!
240Zplus110,
THANKS!
Glue is still holding well - speaker has been kicked a few times and has not let loose.
I used the same glue to attach auto carpet to an under strut sub box I built -- been 5 months and still attached firmly.
Old May 29, 2007 | 10:23 AM
  #46
VO...'s Avatar
VO...
Administrator
I finally completed the mod myself. It was extremely easy, only taking a bit of patients. Here's a couple of shots of the material I ordered. Only $6.95 for a nice roll. Probably enough to wrap 6 grills.
I also included some photos while I was removing the grill. It was extremely easy, while prying opposite the large tabs. No indentions were made on the side panels either.
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-imgp2206.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2207.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2208.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2209.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2205.jpg
Old May 29, 2007 | 10:25 AM
  #47
VO...'s Avatar
VO...
Administrator
Next was the cutting, cut out, and wrapping. I used the sewing method.
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-imgp2212.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2213.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2214.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2215.jpg
Old May 29, 2007 | 10:26 AM
  #48
VO...'s Avatar
VO...
Administrator
And finally, the end product..
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-imgp2216.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-imgp2217.jpg
Old May 30, 2007 | 10:11 AM
  #49
umsta's Avatar
umsta
thats some nice work. the only reason I wouldnt do it is cause my girlfriend tends to be a lil clumsy in my car and would hate to have her heels get caught in the speaker hole by accident and tear but good work!
Old May 30, 2007 | 10:40 PM
  #50
onedirtyz's Avatar
onedirtyz
my car is dirty
https://my350z.com/forum/attachment....7&d=1180463130
damn, i see what you guys mean that the holes aren't even holes..... hmmm
i should ask my papa if he's got a dremel..
Old May 31, 2007 | 08:01 AM
  #51
VO...'s Avatar
VO...
Administrator
It's a real clean job. Just takes a little patients. Good luck.
Old May 31, 2007 | 10:54 PM
  #52
BRONZEE's Avatar
BRONZEE
Club Moderator
Nice one Vo. That looks awesome. I wonder what it would like using a a suitable fabric with a silvery lurex to continue the silver theme through the interior.
Old Jun 1, 2007 | 07:42 AM
  #53
VO...'s Avatar
VO...
Administrator
Thanks. Probably would have matched well. I was partial to the basic black since the car's interior is already accented with black.
Old Jun 24, 2007 | 11:27 AM
  #54
gothchick's Avatar
gothchick
Awesome write up guys~ So I thought I'd give it a try. Turned out great!
First, I went to the fabric store and bought some black sheer, non-stretchy fabric ($3.50).
Then I popped the grills out.
Then I dremeled the obstructive center piece out.
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-dsc01978.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-dsc01979.jpg
Old Jun 24, 2007 | 11:29 AM
  #55
gothchick's Avatar
gothchick
Stretched the fabric over the frame.
Secured it with a ziptie.
Sewed (cinched the edges tight).
Put a thin layer of Gorrilla Glue to hold it all.
Let it cure over night.
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-dsc01980.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-dsc01981.jpg
Old Jun 24, 2007 | 11:31 AM
  #56
gothchick's Avatar
gothchick
Cut the zip tied back section out.
Installed them back into the car doors.
Viola -
Looks very professional. And the sound quality is night & day better than the TARD oem grills. :-)
Attached Thumbnails Write-up: My solution to the stock sound-blocking door speaker grills-dsc01984.jpg   Write-up: My solution to the stock sound-blocking door speaker grills-dsc01986.jpg
Old Jun 25, 2007 | 08:31 AM
  #57
VO...'s Avatar
VO...
Administrator
^^^ looks great!
Old Jun 29, 2007 | 12:42 PM
  #58
jjaujou's Avatar
jjaujou
Very wicked idea, I just might have an activity planned this weekend!
Now if only someone could do a write-up on adding a sub/amp to the 2003 Bose HU... grumble...
Old Jul 5, 2007 | 08:47 PM
  #59
dand070's Avatar
dand070
Just finished this project and turned out great. I'm a horrible at sewing so I couldn't make an elastic cover. I actually sewed the fabric straight to the inside seam of the grill.
Old Jul 14, 2007 | 09:01 AM
  #60
Kwame's Avatar
Kwame
FWIW if anyone needs another set of speaker grills let me know. I have mine sitting around here.
