Australia/New Zealand Queensland, South Australia, Victoria, New South Wales, etc.
Performatance Put In Perspective
Old Dec 15, 2003 | 12:14 PM
ZZZ-35's Avatar
ZZZ-35
Default Performatance Put In Perspective
I thought you guys & gals would like this little article, to put power and acceleration into perspective.
Some Facts About Topfuelers
Just got sent this in an email and found it very interesting!!
* One Top Fuel dragster 500 cubic inch Hemi engine makes more
horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1&½ gallons
of nitro methane per second; a fully loaded 747 consumes jet fuel at
the same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to
drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on
overdrive, the fuel mixture is compressed into a near-solid form
before ignition. Cylinders run on the verge of hydraulic lock at full
throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the
flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from
atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds
up in the affected cylinders and then explodes with sufficient force
to blow cylinder heads off the block in pieces or split the block in
half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate
at an average of over 4G's. In order to reach 200 mph well before
half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to
light!
* Including the burnout the engine must only survive 900 revolutions
under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew
worked for free, and for once NOTHING BLOWS UP, each run costs an
estimated $1,000.00 per second. The current Top Fuel dragster elapsed
time record is
4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top
speed record is 333.00 mph (533 km/h) as measured over the last 66' of
the run
(09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up
the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the RC211V hard up through the gears and blast across the starting line
and past the dragster at an honest 200 mph (293 ft/sec). The 'tree'
goes green for both of you at that moment. The dragster launches and
starts after you. You keep your wrist cranked hard, but you hear an
incredibly brutal whine that sears your
eardrums and within 3 seconds the dragster catches and passes you. He
beats you to the finish line, a quarter mile away from where you just
passed him.
Think about it, from a standing start, the dragster had spotted you
200 mph and not only caught, but nearly blasted you off the road when
he passed you within a mere 1320 foot long race course.
That, folks, is acceleration.
David
Old Dec 15, 2003 | 03:32 PM
zuff's Avatar
zuff
lol
I love top fuelers. Nice read.
Makes you think about how fast is too fast. I think I'll stick to low G acceleration thank you.
Old Dec 15, 2003 | 04:58 PM
DavidM's Avatar
DavidM
I got another one:
- if you stand 3m in front of the top-fuel dragster and this draggster just happens to launch (from standstill of course), then you'll be hit at 160kph.
Old Dec 16, 2003 | 01:46 AM
KY350's Avatar
KY350
That was a very interesting read, especially the comparison with the bike.
Also loved this sentance "Dragsters reach over 300 miles per hour before you have completed reading this sentence." WOW
Thanks David
Old Feb 14, 2004 | 10:16 PM
MY350Z.COM's Avatar
I love the RC211V.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
