Downforce..rear spoilers
If this topic has been 'done to death' tell me, however, search not functioning at present.
Do the rear spoilers of any type on our cars give any gain other than aesthetics?
I read a while ago that the addition of the rear spoiler to the Audi TT (you may remember its original stability problems) gave an additional 70lb of downforce at 200kph.
which rear spoiler are you talking about? It depend on what kind of rear spoiler.
The OEM rear spoiler still can achive a zero lift. The nismo rear spoiler i think also still can achive a zerolift (unsure) but they were aerodynamically tested in wind tunnel.
The GT-wing i guess will provide you a lot of downforce but of course you'll lose the Zero-lift.
I heard Audi TT does have a problem with rear spoiler. It's because the position the spoiler sit. the Audi TT is design very round (like a ball) on the front and back. So i suppose the air can just directed to the back of the car, but not sweeped off the car.
The 350Z if you looked at the touring back end (without OEM spoiler) You'll see a slight higher angle and i think it help to direct the air passed.
But this only my way of thinking. But if i'm wrong i'll be happy that someone would correct me. Because i would willing to learn from Trial and Error too
The Track aero kit is functional FWIW. IMO we don't have enough power or drive at high enough speeds for it to be a concern.
You want an interesting ride drive my 28 year old Landy at 110kph. That's about top speed on the flat, can go a bit more downhill but it's a real thrill ride.
Originally posted by ottonove
did 190-200kph a few times, the car felt quite stable, but still not as good as my previous BMW (325ci), tho the zed get there quicker
Originally posted by 4WSboy
Concencus then rear spoilers unless radical, aesthetic only?
Coefficent of drag is not the same as downforce. (though they are related indirectly because lift requires drag
Spoilers work to smooth or direct airflow around the car. By directing the air away from or to the proper places you can reduce drag and/or lift... both things you want to do. So generally they do not create downforce, but instead reduce lift. Turbulent air, or flows in the incorrect places can cause more drag, or low pressure in the wrong areas, which is why you use spoilers or diffusers to prevent that.
A pure wing on the other hand is about creating downforce and typically isn't related to reducing the coefficent of drag for the car. Creating lift requires increasing drag (downforce is just lift pointed down).
You want less drag for efficency and speed. You want downforce for traction and stability. Its a balence.
)Spoilers work to smooth or direct airflow around the car. By directing the air away from or to the proper places you can reduce drag and/or lift... both things you want to do. So generally they do not create downforce, but instead reduce lift. Turbulent air, or flows in the incorrect places can cause more drag, or low pressure in the wrong areas, which is why you use spoilers or diffusers to prevent that.
)A pure wing on the other hand is about creating downforce and typically isn't related to reducing the coefficent of drag for the car. Creating lift requires increasing drag (downforce is just lift pointed down).
I have the VEILSIDE rear wing and at about 150 youcan see the down force as the wing starts to bend, at 245 the you can feel the road getting harder. I have not put it through a wind tunnel but I believe it works realy well at high speed. I feel very comfortable at high speeds.
Jacko
Jacko
Originally posted by frosty
FAARK! - wot about the wildlife at that speed - where yer gunna fit a 'roo if yer collect one?
FARSTY
FARSTY
Just got the car back on the road and whent to Adelaide for the weeken, nice run - still waiting on rest of body kit to come in from JAPAN..
Jacko
Originally posted by mchapman
Has anyone here seen a photo of what happens when you run into a horse which is facing you one the road? (Dont have any roo shots.)
If not does anyone want to see it?
Seen it....
No, the Track model spoilers, front and rear, reduce the drag coefficient from 0.29 to 0.28. So functional.
