Australia/New Zealand Queensland, South Australia, Victoria, New South Wales, etc.
Plenum and Cats VS CAMS
Old May 18, 2004 | 10:37 PM
mmorris's Avatar
mmorris
Default Plenum and Cats VS CAMS
Hey all,
just wondering which mods i should do first in terms of gaining overall increases in HP.
Should i go with getting the cats and plenum at the same time or should i get cams first.
The car is stock except for cat-back exhaust and pop charger
thanks
Old May 18, 2004 | 11:39 PM
ypwpat's Avatar
ypwpat
It's either how much u want to pay for the Labour. Cams is the most expensive interm of the item and Labour and Time.
So all your choice.
Old May 18, 2004 | 11:53 PM
mmorris's Avatar
mmorris
Really, i was naware of that. I simply though that cams would be the same price as cat and plenum combo
in that case maybe i should go with the cats and plenum???
Old May 19, 2004 | 01:00 AM
apsilon's Avatar
apsilon
Cats and plenum I'd say 3 hours tops to install (with use of a hoist). Cams apparently 10 hours for someone who knows what they're doing.
Cams tend to have most if not all of their gain at the top end and possibly even a loss down low. The plenum and cats would give a more consistant gain.
Old May 19, 2004 | 01:11 AM
ypwpat's Avatar
ypwpat
Oh btw. i remembered sportcompact (i think) made a project on their Z. They Installed the Nismo cam and the Only benefit of the Hp gain is after 5500 RPM above. I seen this on Dyno. So it's pointless if you are using it just driving in the City IMO.
But i'm not sure what other Aftermarket Cam will make.
Old May 19, 2004 | 02:40 AM
ottonove's Avatar
ottonove
If you do the cam, you'll prolly need to upgrade the ECU as well, otherwise its not that much of a gain if using factory prog
Old May 19, 2004 | 04:54 AM
mmorris's Avatar
mmorris
is ti neccesary for ecu reflash with cams and plenum
can this be done here or will it need to be send to usa?
Old May 19, 2004 | 05:19 AM
ypwpat's Avatar
ypwpat
The question about the ECU, i think u can flash it here. because someone done it. I think it's Jacko.
Old May 19, 2004 | 02:26 PM
mmorris's Avatar
mmorris
Sould we do it with PLenumn cats and exhaust ??
Do you know where an how much ???
thanks
Old May 19, 2004 | 02:36 PM
Nathan's Avatar
Nathan
Jacko used a Xede piggyback, which is what we are using on our race car.
Be patient, a Techtom unit has been imported into Australia (thats the unit Technosquare use) but it will take some time to get to grips with the correct reflashing maps.
Our ECU is a very hard unit to decipher & even after 1 year of constant use by Technosquare there is still not universal satisfaction with there reflashing.
With regards to camshafts, they will definatly give you the most power increase in an otherwise stock motor, but at by far the most cost.
Old May 19, 2004 | 05:25 PM
nuff's Avatar
nuff
Nathan, how much would you charge for installing camshafts?
Old May 19, 2004 | 05:55 PM
Nathan's Avatar
Nathan
Aprox $1000.00 inc GST + Parts oil ect.
Old Jun 3, 2004 | 08:47 PM
REDZED's Avatar
REDZED
Take one look at the engine manual and you will see $1000 for a cam install is good value - Its not any easy job.
Looking at the manual suggests that the cam clearances may need to be redone as well(?) given that there are only sized replacement buckets this could add to the cost.
Old Jun 3, 2004 | 09:11 PM
Nathan's Avatar
Nathan
It adds hugely to the cost, each cam bucket is over $50 each & Nissan Aust carry very little stock.
I now only keep the thickest ones in stock & grind them to size to get the correct clearance
Old Jun 3, 2004 | 10:42 PM
apsilon's Avatar
apsilon
Given the cost and fact Nissan doesn't keep stock locally anyway have you considered ordering from the US or Japan? Sure you'd have to plan ahead but I wouldn't be surprised if that $50 part was $10 and always in stock in other markets.
Obviously your solution works but you may be able to cut costs further. Then again I suppose you're not doing all that many cam installs.
Old Jun 4, 2004 | 03:46 PM
Nathan's Avatar
Nathan
Unfortunately Matt you can't plan ahead as you have to install the cams, check your clearances then add or subtract to get the right bucket to do the job.
Odds on Nissan does not have the right size in stock in Oz so theres a minimum 10 day wait.
Old Jun 4, 2004 | 03:56 PM
apsilon's Avatar
apsilon
I know. I was suggesting that if you were installing a decent number of cams as a shop you could order from OS and hold stock of all available sizes and that it may be cheaper than buying locally.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
