pad knockback
Old Dec 11, 2017 | 07:06 AM
Franknbeans's Avatar
Franknbeans
Did you install this after the ABS unit? I was wondering about the ABS unit canceling out the valve.
Old Dec 11, 2017 | 03:28 PM
pchio's Avatar
pchio
Actually, I have never tested it with ABS unit. I have removed it. But the valve is supposedly installed before the ABS.
Old Dec 13, 2017 | 10:46 AM
Voboy's Avatar
Voboy
Originally Posted by pchio
I have installed the 2 psi Wilwood residue pressure valve on my front brake line circuit (right after the master cylinder) for two racing seasons and problem solved.
Just one valve before it splits to FL and FR?
Old Dec 13, 2017 | 02:00 PM
Franknbeans
Would make sense to put it there. Before the split.
My issue, my ride is still a Street Car, more so than track. I am unsure if I want to loose the ABS unit. I assume if I take out the ABS, then the Stability control wouldn't work also.
Is that assumption correct?
Old Dec 13, 2017 | 06:16 PM
pchio's Avatar
pchio
That's correct. One valve before the split.
Old Dec 13, 2017 | 06:17 PM
pchio's Avatar
pchio
Yup, removing ABS also eliminate the Stability control.
Old Dec 14, 2017 | 05:42 AM
Franknbeans
If i was to keep my ABS unit and want to add the pressure valve, before or after the abs unit?
Old Dec 15, 2017 | 07:28 AM
GreyZ's Avatar
GreyZ
I was under the impression that our brake circuits were FR&RL and FL&RR. How were you able to put it just on the front circuit with just one valve??
Old Dec 15, 2017 | 12:01 PM
Franknbeans
THat's news to me. Not sure why any car company would do it that way.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
SanmarinoZ
Oct 21, 2015 10:04 AM
samansharif
Sep 25, 2015 12:31 PM
