Transponder Loaction?
Old Feb 11, 2005 | 07:39 AM
C Ray Z's Avatar
C Ray Z
Default Transponder Loaction?
I just installed a transponder and wire tied it to the grill pointing down . It did not get a pickup at Laguna Seca. In talking to one of the timmers he said that the instructions that say it will go through plastic is wrong and I must have a direct line of sight. So my question is where is everyone mounting there transponder?
Your suggestions greatly appreciated.
Old Feb 12, 2005 | 06:33 AM
ALong's Avatar
ALong
It will go throught thin plastic, but where you located it, it probably was too thick (going through bumper and splash shields) try mounting it to the front inner fender liner pointing down, should work fine.
Old Feb 12, 2005 | 07:13 AM
C Ray Z's Avatar
C Ray Z
Thanks for the reply, Just too many layers of plastic I guess.
Old Feb 12, 2005 | 09:28 AM
daveh's Avatar
daveh
I've seen people make custom mounts with their liscence plate brackets. Not sure of the exact details but something to think about. Maybe you could even get creative with the tow hook.
What kind of transponder did you get?
Old Feb 12, 2005 | 11:51 AM
C Ray Z's Avatar
C Ray Z
I got a hard wired unit and I will add a switch when not in use.
AMB 260
Old Feb 12, 2005 | 03:16 PM
ALong's Avatar
ALong
C Ray Z, just hard wire it into a power wire that is hooked to something that turns off and on with the ignition, that way you never have to worry about turning the transponder on or off yourself...
Old Feb 12, 2005 | 09:42 PM
scubasteve's Avatar
scubasteve
ALong, very good idea. I would hate to forget to turn it on when you think your are on your best lap!
Old Feb 18, 2005 | 04:55 PM
OKC-Silverstone-Trac's Avatar
Heres a pic of mine mounted
http://www.okscca.org/happyteam/imagepages/image8.htm
It is just above the splash shield mounted to the little plastic support piece
HTH,
Bryan
Voboy
295
Aug 7, 2014 03:19 PM
timsam
Jul 1, 2008 02:23 PM
Kabs
Mar 18, 2006 03:57 AM
bcheng4jc
Aug 27, 2004 06:35 PM
