Track Day Check List
Old Apr 9, 2005 | 01:45 PM
shaun_walsh's Avatar
shaun_walsh
Default Track Day Check List
Hey,
I am looking at getting a bunch (7-10) of folks to a track day in May/June. I have only been once and loved it. I don't think any of the others have been before. So I wanted to put togehter a qucik list do(s) and don't(s) for them and myself. Here is what I have so far and would like to get feedback on:
Before we go:
Check tires for tread, get new ones if needed
Get new brake pads, don't guess, just do it
Clean out car of misc. stuff that can fly around
Get a good detail/wash (we are showing off our toys)
Check Tire pressure (What should I tell them? over or under?)
Bring with you:
Folding Chair
Plenty of water
Duffel Bag to hold stuff while you drive
While you are there:
Rent a hemet and timer (If we need them that day)
Listen to the instrructors they know more than you think, and you will be amazed at what they can do with your own car.
That is the list so far, let me know what you would add?
Thanks,
Shaun
Old Apr 10, 2005 | 06:38 AM
Eagle1's Avatar
Eagle1
If you go to the Speedventures site www.speedventures.net
they have a prep check list for the car and I think one for you and your team and friends which is pretty handy to just click and print.
Old Apr 10, 2005 | 07:14 AM
John's Avatar
John
No tread can be a good thing depending on your tyre selection.
Oh, you need to add beer to your list. After a long day at the track, there's nothing better than a ice cold beer to wrap things up.
Old Apr 11, 2005 | 06:52 PM
speedform's Avatar
speedform
Hey,
Before we go:
Bring with you:
Folding Chair
Plenty of water
Thanks,
Shaun
Where is Wildomar? Norcal?
Start tire pressures at OEM recommended psi. For those that haven't been to a track event before I doubt they'll need to adjust anything. Have them learn the course and the car first. Adjustments will come with more experience.
As far as instuctors go, listen to everything they say. Short of knowing where the gas, clutch and brake pedal are there is precious little that can be used to compare street driving with on track experience. Your basically learning to drive all over again.
Have fun and keep the shiny-side up!
Old Apr 11, 2005 | 07:25 PM
shaun_walsh
Thanks, for the input. Wildomar is out by Temecula.
Old Apr 11, 2005 | 09:23 PM
speedform's Avatar
speedform
Ok. Closer than I thought. Are you guys planning to hit a track day next month. If so, I'll be instructing with Speedtrialusa, May 21-22nd. at Streets of Willow. It's a nice, safe course to learn on. cheers,
Old Apr 13, 2005 | 08:27 PM
stumpmj's Avatar
stumpmj
I'd also add a torque wrench, brake fluid, window cleaner, paper towels, sunscreen, a basic tool kit (for you and to help out other people) and spare brake pads for the rear if you have a non-track model. I also bring a floor jack, tire gage, painter's tape (for making numbers), and food (track food=$$$).
Old Apr 14, 2005 | 02:14 PM
zman2's Avatar
zman2
Default Cut off your dust shields
Heat destroys your pads.
Cut off your dust shields.
Try Axxis Ultimate pads.
Old Apr 14, 2005 | 05:10 PM
dnguyent's Avatar
dnguyent
I'm starting to run out of tread on both of my outer edges (Toyo T1S). The inner and outer edges are worn about the same amount. But the inside tread's got plenty of life in them (at least double the amount). I also run 40psi, so it's not due to low pressure. But, when I bought these tires, I noticed that the treads are so much deeper in the center section than the outer edges, so I already speculated that the edges would be completely bald by the time I even get halfway through the center portion of the tread.
Now, do you know if the T1S are one of those tires that's supposed to be last a while on bald edges? We're not going to get rain here for a while, so I'm not to concerned about hydroplaning, but it just sucks because the centers look like they have at least 10k more miles of life.
Old Apr 14, 2005 | 05:16 PM
shaun_walsh
Thanks for help folks, I am going to paln this event for the Willow Springs day on May 21.
shaun
Old Apr 15, 2005 | 08:31 AM
stumpmj's Avatar
stumpmj
Originally Posted by mc350z
stumpmj
i noticed you said extra rear pads. ive noticed this too. i had my rear pads wear out on me twice at track events. why is it that the rears pads wear so easily when the fronts do most of the braking????
They wear quickly for a couple of reasons: 1) The pads are TINY. 2) Because the heat capacity of the rear braking system is so limited, I believe it sees higher temperatures than the front brakes which causes greater pad wear. 3) If you're using a BBK, a fair amount of braking force is redistributed to the rear brakes for better overall braking performance. Cutting off the dust sheilds definently reduces rear brake pad wear. If you look at what the dust shield covers, there's no way for aire to reach the rotor vents!
Old Apr 16, 2005 | 07:26 AM
John's Avatar
John
I have never used my T1S' on track since they are on my Nismo street wheels. However, I will suggest that you take your wheels to a tire shop and have them swap the tires left to right (and vice versa), that way your outside edges will be on the inside on the opposite side of the car (and you'll maintain your directional pattern too). I do this with my R-compounds since I wear the outside part of the front left (since most tracks run clockwise) and the inside part of the right rear (viscous diff = spinning inside drive wheel = quasi "one-tire fire" ).
Old Apr 17, 2005 | 06:20 PM
speedform's Avatar
speedform
shaun
Watch out for turn 9. If you go in too hot it will bite ya! Turn 3 can catch people off guard as well. Respect those two areas and Willow is cake. I'll be instructing at Streets of Willow the same weekend. Maybe I'll stop by and meet you guys. Have fun!
Old Apr 18, 2005 | 01:17 PM
dnguyent's Avatar
dnguyent
Unfortunately, both my inside and outside treads are equally worn. The inside edges are worn due to negative camber and toe-in, while the outsides edges get worn due to cornering on track days. Seems to like I got no way out of this one.
Old Apr 18, 2005 | 07:48 PM
EnthuZ's Avatar
EnthuZ
Yes, there's a solution.......MORE TRACK DAYS!
Old Apr 18, 2005 | 08:45 PM
THX723's Avatar
THX723
Shaun,
I see you're also in California. Where are you located? A bunch of us are scheduled to attack Buttonwillow this May 6th (appox. 3 weeks time).
Check out this THREAD
Cheers,
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
