Suspension Advice and Opinions
Old Apr 19, 2006 | 08:38 PM
BloMyS14's Avatar
BloMyS14
Default Suspension Advice and Opinions
I have a 2003 Track Model Z and I'm looking to get some opinions from people that autox often. What suspension do you have? Why did you decide to go with what you have? My dilemma is I want something that will perform well and still be streetable and not have a harsh ride. I had a fully prepped S14 with KTS coils, and adjustable arms everywhere with spherical bearings and while they were great on the track not too nice on the streets. I'm just trying to decide between a full coilover setup or a spring and shock combo. I think my first upgrades will be sways, I'm not sure on those either I'm leaning towards the Tanabe since that's what I had on my S14. Just looking to get some opinions on setups from people in BS and BSP. Thanks.
Bradley
Old Apr 19, 2006 | 09:11 PM
jun14scr's Avatar
jun14scr
suspension set ups in BS usually include a hotchkis/350evo front sway and koni SA/DA shocks. nothing really too exciting here, but then again it's a stock class.
Old Apr 20, 2006 | 05:26 AM
christoc's Avatar
christoc
If you're looking for BS jun14scr is correct, a set of Koni adjustables and a sway bar are your only options.
BSP I don't know about, never looked at anything other then BS for my car.
Old Apr 20, 2006 | 02:22 PM
350Zteve's Avatar
350Zteve
If you go BSP, I would recommend adjustable sway bars so you can really dial in to rotation for tight courses. As for coilovers, you probably should stay with spring rates in 550# range, anything stiffer will probably be more than your looking for in a street ride.
I run Tien Flex and the springs are 667# all round and its stiff. Its streetable, but its not my daily driver, so I like it.
Old Apr 20, 2006 | 09:29 PM
BloMyS14's Avatar
BloMyS14
What is 550 = in Kg? I'm leaning towards the Cusco Zero 2 coilovers. Spring rates are 10 kg in the front and 7 kg in the rear. Aren't the Flex's 12 front and rear? Do you think I will need the adjustability in the sways?
Old Apr 20, 2006 | 09:36 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
the apexi exv are a good setup, i have it dialed in very stable and tight for the smaller courses that are common in cincy SCCA.
Old Apr 20, 2006 | 09:48 PM
350Zteve's Avatar
350Zteve
Originally Posted by BloMyS14
What is 550 = in Kgf? I'm leaning towards the Cusco Zero 2 coilovers. Spring rates are 10 kgf in the front and 7 kgf in the rear. Aren't the Flex's 12 front and rear? Do you think I will need the adjustability in the sways?
Each kgmm = 55.7psi. So, 10kgmm springs are ~557PSI
Old Apr 21, 2006 | 09:41 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
When my car was a daily driver/autocross/track car I ran the 350EVO sways and Tien Flex w/EDFC and loved it. It may not be the absolute best setup for handling but the EDFC gave a good variety of stiffness. I ran full stiff on the track and full soft on the street. That would be my vote since you probably arent looking to win national level BSP races.
350Z_Al
Oct 29, 2020 07:44 PM
wanderingstuden
Jan 28, 2016 07:03 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
