Portable air tanks
Old May 2, 2006 | 09:47 AM
Snowhiteboiler's Avatar
Snowhiteboiler
Default Portable air tanks
Has anybody used a portable air tank before? I found some at Lowes and Sears for under $40. I would just need it to add air for a track day, would a 5 or 10# bottle be enough? Is this something I would then fill up at a gas station before hand? Thanks
Old May 2, 2006 | 02:48 PM
Tekwon-V's Avatar
Tekwon-V
go for the 10lbs at least. i had the 7lbs one and that was barely enough. i have a 15lbs one now.
yes, just fill up at the gas station.
Old May 2, 2006 | 04:34 PM
Kolia's Avatar
Kolia
Actually, fill up at the track. That air is usually drier.
Old May 2, 2006 | 04:56 PM
DmanG281's Avatar
DmanG281
I got mine from walmart and just upgraded the hardware.
Old May 2, 2006 | 05:16 PM
myG35zx's Avatar
myG35zx
Nitrogen bottles.
Old May 2, 2006 | 06:14 PM
christoc's Avatar
christoc
I have a tank, but I find I use the air at a track or autocross as it's usually on a compressor and far easier to fill up.
Old May 2, 2006 | 07:04 PM
jun14scr's Avatar
jun14scr
most gas station pumps have trouble getting the PSI up high enough. then again, maybe that's because i run 60psi on my hoosiers. i'm sure one tank full would be enough to fill up 710s.
if you want to spend a little more for some lighter tanks, there are high quality aluminum tanks out there for about $80. http://www.behrents.com/
did you read my thread on the high pressure compressed air tank? very small, compact, with 3500psi of nitrogen (better than using conventional air, more stable, less moisture).
Old May 3, 2006 | 04:14 AM
myG35zx's Avatar
myG35zx
I searched, but did not find such a thread. Do you have a link?
Old May 3, 2006 | 12:47 PM
jun14scr's Avatar
jun14scr
okok, here we go:
things you need, all of which can be purcahsed at a welding supply store... even ebay too.
1. bottle. $50-100
-3500psi
-bottle size is up to you
-$5 to fill up
2. regulator. $50-XX
-step down the 3500psi to about 125psi
-dual stage might be cheaper
3. hose. $20
-can be purchased pretty much anywhere
-15' yellow coiled seems to be popular
-don't forget the attachments for the valve
http://www.overboost.com/story.asp?id=1291
Old May 4, 2006 | 04:58 AM
myG35zx's Avatar
myG35zx
Thanks.
Old May 4, 2006 | 05:29 AM
Kolia's Avatar
Kolia
Lets not forget that anybody wanting to run Nitrogen in his tires should empty/vaccum his tires to get rid of as much air as possible first.
Old May 4, 2006 | 06:01 AM
jun14scr's Avatar
jun14scr
i've heard debates to whether co2 or n2 is better. opinions?
Old May 4, 2006 | 12:11 PM
myG35zx's Avatar
myG35zx
A freind of who is a crew member for The Racers Group (Daytona Prototypes) and routinely wrenches on 996/7 GT3 Cup Cars and RSR's swears by nitrogen. He has two systems (high and low pressure). The low pressure for tools and filling tires. The high pressure for car jacks - which is damn cool. I'm building a system for my track trailer with a 20 pound low pressure nitrogen bottle.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
