fuel starvation at the track
Old May 25, 2006 | 06:51 AM
ALong's Avatar
ALong
Originally Posted by EnthuZ
An easy mod. Drop the entire rear subframe, remove the OEM fuel tank, cut it in half to install the foam, re-weld the tank, and simply re-install the tank and rear suspension!
Ask your dealer if they'll do it along with their recall.
Just drop the tank out, it has access holes in the top for the fuel pump etc, you cut the tank foam into blocks, as large as you can squeeze through the opening, then do it piece by piece. You dont have to fill the entire tank with foam, you just need to get enough foam around the pick ups to keep the fuel from sloshing away.
