Redline Time Attack! @ Buttonwillow Dec 2 & 3
Old Dec 22, 2006 | 11:42 AM
  #141
ALong's Avatar
ALong
I know it varies but all being equal a T2 car will be several seconds a lap faster than an ITS car. Show me an ITS car faster than Schotz or any of the other fast CAli T2 cars and I will show you an illegal ITS car.
Old Dec 22, 2006 | 12:05 PM
  #142
betamotorsports's Avatar
betamotorsports
As the T2 cars are being developed they are getting faster and I agree that, on paper, the T2 cars should beat the ITS cars. A good example is the lap records at Road Atlanta where the "Runoffs" for IT (the ARRC) are run. In March 2006 Will Turner in a T2 M3 beat Chet Whittle's ITS lap record from the SARRC in 2004 by .80 seconds.
Old Dec 22, 2006 | 12:21 PM
  #143
ALong's Avatar
ALong
Originally Posted by SuperKool
Hey all,
With all the discussion about tires and how they apply to the rules, I'd like to clarify a little about the rules and why they are written the way they are for the Street Class.
For each class we run in the Time Attack, we needed to have a general rule that separated each class. In Time Attack racing, the build of the car is fairly open. You do can do just about anything to your car to make it go fast. There are no sanctioned rules that limit your ability to go fast. This isn't wheel to wheel racing and the idea is to get the fastest lap you and your car are capable of. With that being the spirit of Time Attack racing, we still needed a class divider. With the build up of your car being wide open, your tire choose is the only real handicap that can be applied to lap time. Therefor, the tires that you can use in any given class is what defines the class. We all know that tread wear ratings are not all equal, however we can determine that all tires with a tread were rating of 140 or higher are defiantly street tires and not of the R-Comp category. The Street Class can use tires with a tread were rating of 140 or higher, and therefor you won't find any racing tires in that class. The sprit of the street car class is just that.... A street driven car that can compete in a TIME ATTACK race without having to be a full blown race car. This has worked out very well through out this last year of Time Attack events. What has been happening is that people who build up their car to run in the Time Attack Street Class are limited by the tire choose and although some drivers have incorporated huge amounts of power, they have not been able to utilized the power due to the restriction of tires in the street class. This of course prompts people to use a R-Comp tire and thus moves them into the Modified class were a Time Attack built car belongs. This last year of hosting the Redline: Time Attack has proven the rules to work well. As it shows that the street class has been dominated by cars with less power, or less built cars that compete well with better chassis and suspension tuning over raw power.
Now the Modified and Unlimited Class is another story altogether, but I hope you get more of a feeling for the street class and why the rules were written the way they are.
You guys are going about equalizing cars the completely wrong way. Yes tires may limit the cornering speeds but a "Street Class" 350Z with a 500hp twin turbo motor is going to be faster than an actual street legal N/A 350Z with light mods that the majority of people are going to run. In essence what you have done is opened the barn door and said "hey run 500-600hp motors their legal (essentially a Unlimited class Motor), but you have to run street tires to equalize the competition" How is running street tires going to equalize anything when your running a lightly modded car (which should be the philosophy in Street Class) against cars with 200-300hp more than you have?
One thing I have learned from Racing is that nothing beats HP, thats how cars that are pigs in corners but rockets on straights can product suprisingly fast lap times.
Your philosophy for the Street Class should be cars close to stock. Who cares what tires they run on, let them run Hoosier but write some rules that make sense. This is what I would recommend for Street Class:
Require all engines to run standard OE induction method, ie: N/A must remain N/A, Turbo must remain Turbo. Allow intake and exhaust to be free. Allow engine management to be free. Require all engine internals to remain stock OE. Allow springs, shocks and swaybars to be free. Require fenders, doors and trunk to be stock (ie: no wide bodies) allow aftermarket Hoods and Front/Rear spoilers and side skirts.
Old Dec 22, 2006 | 12:29 PM
  #144
betamotorsports
Except ground effects, light weight, and wings.
Old Dec 22, 2006 | 04:07 PM
  #145
mhoward1's Avatar
mhoward1
I'd have to agree with that...not many street machines with 300-500 HP can beat the Radicals, Stohls, and F2000 machines out there.
Old Dec 22, 2006 | 04:16 PM
  #146
ALong's Avatar
ALong
Unless they are running the same day you cant compare the lap times, track temprature and track condition can affect lap times by several seconds. 6 or 7 years ago ITS times were comparable to T2 but nowadays, running at the same track on the same day, a well driven T2 car will be several seconds faster.
Old Dec 22, 2006 | 04:19 PM
  #147
ALong's Avatar
ALong
HA, HA. The point I was trying to make is that cars, like the T2 camaro, can set fast times purely from hp, they are laughably slower in the corners comparted to a T2 350Z.
Old Dec 23, 2006 | 04:32 AM
  #148
Eagle1's Avatar
Eagle1
The cars like the Chiron, Ariel Atom and Radical that I have come across on the track days are insanely faster than 500rwhp street cars. There is just no way that a track only sled will fail to wipe the floor with street cars, assuming equal driver skill. The power to weight ratio of the Atom is 600bhp per ton........(the supercharged version that puts out more than 300bhp on a 1,000lb body). that is almost double what the TT Z and G cars put out for track and street. Then put on some aero and yikes. The only place on the tracks that I have run with them where I could beat them resoundingly was on the front straight at Cal Speedway where the high hp could just out grunt them above 120mph, their aero was creating drag, and with my high speed torque it was possible to keep pulling on them. But any ape can just hold the wheel still and keep the right foot down....no joy there. And lap times? No contest. We could do low 1:50's on the road course in Z and G cars with the Roval (high banked turns 1 and 2 they use from the NASCAR track). The little rockets were doing high 1:30's to low 1:40's.
But they don't have stereo, air conditioning, etc. either. Totally fun toys.
Old Dec 23, 2006 | 05:48 AM
  #149
ALong's Avatar
ALong
There is always going to be one or two exceptions to a rule, it would be easy for the organizers to put these cars automatically into the modified or unlimited classes (like they do with the Ferrari's and Porsche's). My point is this supposedly "street stock" class leaves a lot of us with midly modded Z's etc totally outclassed when someone shows up with a twin-turbo charged Z. A turbo charged Z would not be considered "street stock" by any other organization, and to say that requiring everyone to run street tires will somehow equalize a car with 500hp to a car with 300hp is unrealistic.
Old Dec 23, 2006 | 05:49 AM
  #150
ALong's Avatar
ALong
One thing you failed to take into account. Turner was running on Toyo RA1's which are 2-3 seconds a lap slower than Hoosiers. This is why, when he showed up at the runoffs and was about 2-3 seconds off the pace in testing, he dumped the Toyos and put on Hoosiers with the lettering grinded off the sidewalls....
Old Dec 23, 2006 | 06:16 AM
  #151
betamotorsports
Didn't know that. Kinda like the IRL and Champ Car guys that run purple powder coated Hypercoils when they are sponsored by Eibach.
Old Dec 23, 2006 | 10:50 AM
  #152
ALong's Avatar
ALong
Yeah, he was sponsored by Toyo, dont know if they caught wind of this but everyone in the padock knew what he did. Turner knew he didnt have a chance at all running the Toyo's.
Why are the IRL guys running Hypercoils instead of Eibach, are they really that much better?
Old Dec 24, 2006 | 09:05 AM
  #153
betamotorsports
They thought so and went to a lot of trouble to run them. Personally, I have always run Hypercoils because their actual rates have always been within 1% of the rate engraved on the spring, even after coil binding and a couple years of use. No need, IMHO, for me to try something else and I'm paying for my own stuff.
Old Dec 27, 2006 | 04:11 PM
  #154
kognition's Avatar
kognition
My company will be going thru the Radical sometime this spring for Radical West
to shave at least another 75lb's off of this car with new production parts. Then there is truly going to be no hope.
Obadabot
Jun 18, 2023 11:31 PM
