Question for the Professionals...
Old Jan 25, 2007 | 11:40 AM
JCZ33's Avatar
JCZ33
Default Question for the Professionals...
Ok, maybe not professional, but those with expereince would help.
Considering that the 350Z from the factory has a near equal front and rear track width; whay would the dynamic affects be to widening the rear track by about 1".
Old Jan 25, 2007 | 01:35 PM
betamotorsports's Avatar
betamotorsports
Increasing track width decreases lateral load transfer for that end of the car. Generally in racing a production based sedan you want the front track width wider then the rear. It helps the car turn in and put power down because you'll get less understeer from the front as more power is applied. The slower the corners the more benefit you'll see from front to rear track width differences. The car will be more difficult to drive at the limit.
Doing the reverse, as you've asked, will make the car easier to drive at the limit but ultimately it will be slower.
Old Jan 25, 2007 | 01:47 PM
THE TECH's Avatar
THE TECH
John, the lurker, comes through with another good one.
Old Jan 25, 2007 | 05:13 PM
JCZ33's Avatar
JCZ33
So, Since I am not a track racer, having the rear at 1/2" wider track is not going to ruin my day?
Got it.
You are the track master, thank you.
Old Jan 26, 2007 | 07:10 AM
betamotorsports
Your day should not be affected by your wider rear.
Old Jan 26, 2007 | 03:21 PM
MoodDude's Avatar
MoodDude
Unless it is on a woman!
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
